Joshua Kenny
- 6
:As the picture shows, there are two NaClaq solutions. One is saturated while the other is not and both of them are at the same temperature. There are three questions asked:
a) Above which solution is the vapor pressure of water, PH2O, greater? Explain.
b) Above one of these solutions, the vapor pressure of water, PH2O, remains constant, even as water evaporates from solution. Which solution is this? Explain.
c) Which of these solutions has the higher boiling point? Explain.
2. Homework Equations
As Raoult's law states: Psolution=Psolvent*Xsolvent
where Xsolvent is the mole fraction of the solvent in the solution. In this case, Xsolvent is XH2O.[/B]
**For question a), solution (2) has a greater PH2O value because the amount of solute (in this case NaCl) is less than that of solution (1) therefore Xsolvent of solution (2) is greater than that of solution (1).
**For question c), solution (1) has a smaller PH2O value and therefore the boiling point of solution (1) would be higher than that of solution (2).[/B]
I'm left confused by question b) because I cannot prove how PH2O could remain constant. I would be glad if someone could explain the logic of this question. Please check as well if the previous answers/explanations for question a) and c) are appropriate or not.
