Variable Coefficient Differential Equation problem
In summary, the conversation discusses the difficulty of solving a differential equation with variable coefficients that is used to determine voltage and current variations based on temperature and distance. The speaker has tried using different software programs but has not been able to find a satisfactory solution. They are seeking resources or guidance on how to solve the equation. The expert offers two possible methods, including the use of Fourier transforms and the Frobenius method, but cautions that the solution will involve non-elementary functions.
mknut389
I have been trying to solve a differential equation that will be used to determine voltage and current variations based on ambient temperature and the distance along the line.
To avoid the complicated derrivation of the current equation... the current based off the temperature variations should be able to be solved from
I''-xI=0
when I is a function of X
I have searched all over to try and find solution to differential equations with variable coefficients, but everything I find is in a different form (and this cannot be adjusted to fit in that form).
My attempt at the solution consist of using MATLAB, MAPLE, and MATHEMATICA. All of which give crazy solutions which I do not understand.
Is there anywhere you could provide me which I could teach myself, or even better, give a description of how to solve it?
Thanks
MK
I thought this looked familiar. Your differential equation is an http://calclab.math.tamu.edu/~fulling/m412/f07/airywkb.pdf" . You're solutions will be in the form of Airy equations, which by the way are non elementary functions, but that's OK. It just means they're not on pocket calculators.
Technically, to obtain the solution, you can take the Fourier transform, solve a first order ODE in the Fourier domain to find a representation for the Fourier transform of y, then take the inverse Fourier transform of that representation. At this point, you can go no farther because the integral has no elementary closed form. It's used by many as the definition of the Airy function(s).
If you don't like Fourier transforms, there's always the Frobenius method... http://mathworld.wolfram.com/AiryDifferentialEquation.html" . However, I don't recommend this for human consumption.
FAQ: Variable Coefficient Differential Equation problem
What is a variable coefficient differential equation problem?
A variable coefficient differential equation problem is a type of mathematical problem that involves finding a function that satisfies an equation where the coefficients are not constant, but rather vary with one or more independent variables.
What are some real-life examples of variable coefficient differential equation problems?
Variable coefficient differential equation problems can be found in many areas of science and engineering, such as in population dynamics, chemical reactions, heat transfer, and electromagnetism.
What techniques are used to solve variable coefficient differential equation problems?
There are several techniques that can be used to solve variable coefficient differential equation problems, including separation of variables, substitution, and series solutions. Numerical methods, such as Euler's method and Runge-Kutta methods, can also be used for approximate solutions.
What are the challenges in solving variable coefficient differential equation problems?
One of the main challenges in solving variable coefficient differential equation problems is that the coefficients are not constant, which makes the equations more difficult to solve analytically. Additionally, the equations may be nonlinear, leading to complex solutions.
How are variable coefficient differential equation problems used in scientific research?
Variable coefficient differential equation problems are commonly used in scientific research to model and understand complex phenomena in many different fields. They can help researchers make predictions, analyze data, and develop new theories and methods.
