Variable mass beans falling on a platform
In summary: Yes the scale will always read the total weight that left the spigot. Here it is a general argument. We know that ##v=\sqrt{2gh}##, that the mass that has reached the scale by time ##t## is ##m=dm/dt(t-\sqrt{2h/g})##, that ##dv/dt=g## and that the mass that has left the spigot by time ##t## is ##tdm/dt##. So##F=m\frac{dv}{dt}+v\frac{dm}{dt}=\frac{dm}{dt}(t-\sqrt{2h/g})g
Jenny Physics
111
A spigot pours beans onto a scale platform.
At a time t = 0.0 sec, the spigot is opened and beans begins to pour out (with initial velocity 0) at a rate of 1.00 kg/sec onto the platform from a height of 10.0 m above.
(a) At t = 10.0 sec, what is the weight of beans on the platform?
(b) What does the scale read at this time?
It takes ##t=\sqrt{\frac{2h}{g}}\approx 1.43 secs## for each bean to reach the platform.
In 10 secs, 10kg of beans will have left the spigot but only ##10/1.43\approx 7kg## have reached the platform. That is the weight of beans in the platform. My understanding is that the scale will read ##7kg##?
10 kg have left the spigot, that's true. If it takes 1.43 s for a bean to drop, how many kg worth of beans are in the air at any particular time?
Also, the scale will read more than the weight of beans that have piled up on it. Why?
Likes Jenny Physics
We don't care how many are in the air only how many have reached the platform at t=10s, i.e 7kg?
Good point with the scale reading. I imagine that in addition to the beans that have landed, the impulse of those that landed must contribute although not sure how?
The number of beans on the platform is the number that have left the spigot minus the number that is in the air.
You are correct about the impulse. How would you find the force associated with the beans striking the platform? What expressions do you know?
Likes Jenny Physics
Ok the last beans that can reach the platform by ##t=10s## must have left by ##t=8.57s## (if they take ##1.43## to get there) so at ##t=10s##, the mass of beans on the platform is ##8.57kg##.
I know that the velocity of those beans when they hit the platform is ##v=\sqrt{2gh}=14m/s##. So the impulse of the ##8.57kg## will be ##14\times 8.57\approx 120 m/skg##. Is the scale weight ##8.57*9.8+120/10##?
Not quite right. Sir Isaac Newton said $$F=\frac{dp}{dt}=\frac{d(mv)}{dt}=v \frac{dm}{dt}+m\frac{dv}{dt}$$ Does this give you an idea about finding the impulse force?
Likes Jenny Physics
For part (a) the weight of beans on the platform will be ##8.57\times 9.8\approx 84N##
For part (b) the impulse will be ##F=14\times 1+8.57\times g=14+84=98N##. So the scale will read ##98/9.8=10kg##.
That is correct. The weight read by the scale is equal to the total weight that left the spigot. Now, do you think this would always be the case or is it a coincidence because of the simple numbers given? You have 10 s for the time, 10 m for the height and 1 kg/s for the rate. Would the reading be something different from "the total weight that left the spigot" if the time were 6.38 s, the height 7.32 m and the rate 0.65 kg/s?
Likes Jenny Physics
##F=m\frac{dv}{dt}+v\frac{dm}{dt}=\frac{dm}{dt}(t-\sqrt{2h/g})g+\sqrt{2gh}\frac{dm}{dt}=tg\frac{dm}{dt}## which is the mass that left the spigot during time ##t##.
Well done. :smile: Substituting numbers at the very end gives you insights that would be hidden if you substitute up front.
Also note that you dropped a ##g## in your expression. The force should be ##F=gt\frac{dm}{dt}##. It's the "reading on the scale in kg" that is ##t\frac{dm}{dt}.##
Likes Jenny Physics
Thank you. Fixed the missing ##g##
Related to Variable mass beans falling on a platform
1. How does the mass of the beans affect their fall on the platform?
The mass of the beans affects their fall on the platform because it determines their weight and therefore their acceleration due to gravity. Heavier beans will fall faster and with more force than lighter beans.
2. What is the impact force when the beans hit the platform?
The impact force when the beans hit the platform depends on their mass and velocity. The force can be calculated using the equation F=ma, where F is the force, m is the mass, and a is the acceleration due to gravity.
3. How does the height of the platform impact the beans' fall?
The height of the platform will affect the beans' fall because it determines the potential energy they possess before falling. The higher the platform, the more potential energy the beans have, which will result in a greater force when they hit the ground.
4. Is there a maximum number of beans that can be dropped on the platform?
There is no maximum number of beans that can be dropped on the platform. However, the more beans that are dropped, the greater the force of impact will be. It is important to consider safety precautions and the structural integrity of the platform when choosing the number of beans to drop.
5. Does the shape or size of the beans affect their fall?
The shape and size of the beans will affect their fall as it can impact their air resistance and therefore their terminal velocity. Larger or more aerodynamic beans may fall faster than smaller or less aerodynamic beans.
