TFM
- 1,026
Consider a particle in the harmonic potential [tex] V(x)= \frac{m\omega^2 x^2}{2} [/tex]. Its lowest energy eigenvalue is [tex] E_0=\hbar \omega/2 [/tex] and the eigenfunction associated with this energy, ie the ground-state wave function, is
[tex] \phi_0(x) = \left(\frac{m\omega}{\pi \hbar}\right)^{1/4}e^{(m\omega/2\hbar)x^2} [/tex]
a)
Determine the limits of the classical motion in this potential (the “classical turning points”), ie the smallest and the largest values of x that a classical particle can reach if it has the total energy E0.
b)
Assume that the wave function of the particle is the stationary state [tex] \phi_0(x) = e^{-iE_0t/\hbar} [/tex]. Determine the probability (in the form of an integral) of finding the particle outside the region where classical motion can occur. By making an appropriate change of variable in the integral you obtain, show that the answer is independent of m, [tex] \omega [/tex], and [tex] \hbar [/tex].
c)
Calculate the variance [tex] \Delta \hat{x} [/tex] in the ground-state of the system and compare it to the limits of the classical motion.
useful integral:
[tex] \int^{\infty}_{-\infty} z^2 e^{-\alpha z^2} dz = \frac{1}{2}\sqrt{\frac{\pi}{a^3}} [/tex]
Variance = [tex] \sqrt{<x^2> - <x>^2} [/tex]
[tex] <x^2> = \int \phi^* x^2 \phi [/tex]
[tex] <x> = \int \phi^* x \phi [/tex]
I have done all but the location of reflection for (a), and I have done (b), but I am slightly stuck for (c)
I have used the formulas given above, with:
[tex] \phi_0(x)^* = \left(\frac{m^*\omega^*}{\pi \hbar^*}\right)^{1/4}e^{-(m\omega/2\hbar)x^2} [/tex]
however when I put them in the variance formula, because it is e^x x e^-x, they cancel,so I am just left with:
[tex] <x> = \left(\frac{m\omega}{\pi \hbar}\right)^{1/4}\left(\frac{m^*\omega^*}{\pi \hbar^*}\right)^{1/4}x [/tex]
and
[tex] <x^2> = \left(\frac{m\omega}{\pi \hbar}\right)^{1/4}\left(\frac{m^*\omega^*}{\pi \hbar^*}\right)^{1/4}x^2 [/tex]
This doesn't seem to coincide with the useful integer given...?
Have I gone wrong somewhere?
Many Thanks,
TFM
