Variation in electrical lines of forces with intensity.
In summary, the number of lines per unit area through a surface perpendicular to the lines is proportional to the magnitude of the electric field in that region. This means that the field lines are closer together in areas with a stronger electric field and farther apart in areas with a weaker field. This can be seen in Figure 23.20, where the density of lines through surface A is greater than the density through surface B, indicating a stronger electric field on surface A. The direction of the lines also indicates that the field is nonuniform. However, it is important to note that the number of lines is not a measure of the intensity of the field, but rather the density of lines is what determines the field's strength. This can be seen in
dE_logics
742
This is what a book says -
“The number of lines per unit area through a surface perpendicular to the lines is
proportional to the magnitude of the electric field in that region. Thus, the field
lines are close together where the electric field is strong and far apart where the
field is weak.”
“These properties are illustrated in Figure 23.20. The density of lines through
surface A is greater than the density of lines through surface B. Therefore, the magni-
tude of the electric field is larger on surface A than on surface B. Furthermore, the fact
that the lines at different locations point in different directions indicates that the field
is nonuniform.”
What I concluded from the above -
That means the total intensity of E.F passing though an area is independent of the number of lines of force, depends more its density and is directly proportional to it.
So even if we are comparing 2 areas having areas A and 2A and suppose x lines of forces passes through them so the total intensity of the field at A should be greater than 2A, if the areas are charged partially, then the force on A will be more than 2A despite the fact that the number of lines of forces passing through both of them are the same the E.F on A will be higher cause the density of the lines are A is higher.
Talking about insane analogies, Suppose we have 2 area A and 500k A, and if the density of the lines in A is more than 500k A, even though the difference is very less A will get more E.F and so if the areas are charged, A will generate more attraction relative to 500k A, even though the number of lines of forces passing through 500k A is like 490 times of A.
So what final conclusion we have here is that from where the lines of forces pass, it just means that an E.F is present there and does not has to do with the intensity; only the density of lines has to do with the intensity.
Considering the above, suppose we have 2 areas -
http://img223.imageshack.us/img223/5449/2areas.jpg
Then even if the small area is one trillionth of the larger area, it will experience more force.
Well...sounds insane to me.
Now following Columb's law the density of lines of forces should decrease with distance, however major ambiguities come by when considering the geometry, you see when comparing a point charge and a plate, the density decrement per unit space of the point charge will be more than the pate; considering this r2 relation should not be applicable to the plate.
And finally what do you mean when one line of force passes through an area?...I mean the ield at this state should have a minimum possible value, but still needs to decrease with an inverse square relation to distance...what will happen then?
:cry:
I got my exams people!
I can't leave this chapter!...my course basically is comprised of DC circuits...which's done with ease, EM and AC.
I was panning to leave EM considering the nature of my problems, but Ineed that while doing AC.
The 'inductance' crashes all plans!
And this is exactly the problem where I left.
Still no responses?
I am not sure I understand your question.
But, you DO understand that the lines are not actually "real" in any way, don't you?
They are mathematical constructs that are used to show what the field "looks" like (i.e. how it would affect point charge); they are no more real than the contour line you will find on maps that are used to illustrate the topography.
Hence, the "scale" (total number of lines) for any given picture is arbitrary; it is the DENSITY of the lines that tells you where the field is strongest but that will be true whether you are using 10 or 100 lines.
FAQ: Variation in electrical lines of forces with intensity.
What is "variation in electrical lines of forces with intensity"?
Variation in electrical lines of forces with intensity refers to the changes in the strength or magnitude of the electric field lines as the intensity of the electric field changes. This is often observed in experiments where the distance between two charged objects is varied, resulting in changes in the electric field and its associated lines of force.
Why is it important to study the variation in electrical lines of forces with intensity?
Studying the variation in electrical lines of forces with intensity is important because it helps us understand the behavior of electric fields and their impact on charged particles. This knowledge is crucial in many fields such as electronics, electromagnetism, and energy generation, and can also aid in predicting and controlling the behavior of electrical systems.
How does the intensity of the electric field affect the variation in electrical lines of forces?
The intensity of the electric field directly affects the variation in electrical lines of forces. As the intensity increases, the electric field becomes stronger, resulting in more closely spaced and denser lines of force. On the other hand, a decrease in intensity leads to a weaker electric field and a wider spacing of the lines of force.
What factors can influence the variation in electrical lines of forces with intensity?
There are several factors that can influence the variation in electrical lines of forces with intensity. These include the magnitude and polarity of the charges involved, the distance between the charges, and the medium in which the electric field exists. Additionally, the presence of other charged objects or conductors in the vicinity can also affect the variation in electrical lines of forces.
How is the variation in electrical lines of forces with intensity measured or quantified?
The variation in electrical lines of forces with intensity can be measured or quantified using a variety of techniques, such as using an electric field probe or a charged particle detector. These instruments can provide numerical values for the electric field strength, which can then be used to calculate the variation in the electric field lines. Additionally, computer simulations and mathematical models can also be used to study the variation in electrical lines of forces with intensity.
