neelakash
- 511
- 1
We know, in optics Fermat's principle is written in analogy with principle of Maupertuis in Classical mechanics (given by [tex]\delta S=\delta\int\vec{p}\cdot d\vec{l}=0[/tex]). In terms of the wave vector it is written as [tex]\delta\psi=\delta\int\vec{k}\cdot d\vec{l}=0[/tex]. Here [tex]\psi[/tex] is known as eikonal (or, phase).
For a monochromatic wave of fixed frequency,[tex]|\vec{k}|=\frac{\omega}{v}=\frac{\omega}{c}\frac{c}{v}=|\vec{k_0}|\frac{c}{v}=|\vec{k_0}|n[/tex] ([tex]n[/tex] is refractive index). Using that the above reduces to
[tex]|\vec{k_0}|\delta\int\ n\ dl=0[/tex] or [tex]\delta\int\ n\ dl=0[/tex] which can be identified as more familiar form of Fermat's principle.[we have calculated the line integral along the direction of [tex]\vec{k}[/tex]]
Notice that it is reached by setting the variation of [tex]\psi[/tex] to zero like in mechanics we have principle of Maupertuis by setting variation of action [tex]S[/tex] equal to zero. It is known that action is minimized in mechanics to get the classical path traced by the system. But is the case same with the phase eikonal also? Landau (section 53-54) identifies [tex]\vec{k}=\nabla\psi[/tex] and thus [tex]\psi[/tex] is a scalar potential of a conservative field. That means whatever path you choose from A to B,the integral [tex]\int_{A}^{B}\vec{k}\cdot\ dl=\int_{A}^{B}|\vec{k}|\ dl[/tex] will remain the same. Anyway, the minimization of optical path is evident from the familiar form of Fermat's principle: [tex]\delta\int\ n\ dl=0[/tex] what can be proved using geometry.
The only difference is that action [tex]S[/tex] is not constrained by any partial differential equation like [tex]\psi[/tex] is. [tex]\psi[/tex] is constrained the eikonal equation given by [tex](\nabla\psi)^2=\ n^2[/tex]-here [tex]n[/tex] is refractive index...Anyway, what I wonder is that whether it is possible to call the problem of optics a variational problem: we are not actually minimizing [tex]\psi[/tex] for [tex]\psi(B)-\psi(A)[/tex] is the same for all the paths...(unless you constrain it via eikonal equation).
Do people know the explanation for it? May be I am missing something...
