Variation of Force-time graph for person opening parachute
In summary, the conversation discusses the concept of terminal velocity and its relation to air resistance and gravity for a skydiver. The question asked is about the force of air resistance when the skydiver reaches terminal velocity, and it is clarified that the parachute is opened after reaching terminal velocity. The conversation also mentions the proportional relationship between force and velocity and the limitations of the given graphs. The final conclusion is that the force of air resistance is constant and equal to the weight of the diver when they reach terminal velocity.
toforfiltum
341
F∝v
I chose C because I thought that at time T after opening the parachute, the resisting force on the diver will increase. But it is not so since the answer is B. Is it because the diver has reached terminal velocity? Even so, shouldn't the increase in surface area from the parachute increase resisting force?
Perhaps it means to say that the parachute isn't opened until beyond the graph's end? It does say that terminal velocity is reached at t = T.
Likes toforfiltum
Think about what terminal velocity means. What is the acceleration?
What must the force of air resistance be when the skydiver reaches terminal velocity?
Likes toforfiltum
Remember that the question says "Beyond the time shown in the graphs, she opens her parachute." So you should not consider the parachute in answering the question. It is only from release to some time after terminal velocity you should consider.
You are given that force is proportional to velocity. Probably that isn't accurate, but you are given this as a basis.
So how does force vary with time? Without solving the differential equation (and without being given the actual equation for wind resistance you can't) you do know some things. When the diver first starts to fall she will be moving very slowly. So for the first little while wind resistance will be very small. That means that velocity increases linearly with time for the first little while. But as soon as velocity starts to grow so does wind resistance.
Terminal velocity means she reaches a constant speed where wind resistance just equals gravity.
Reaching terminal velocity is an asymptotic thing. There isn't an abrupt corner between increasing speed and non-increasing. Wind resistance builds up, rate of acceleration gradually approaches zero.
Now looking at these graphs they all have problems. When you are doing a multiple choice kind of quiz you have to choose the best possible answer.
Likes toforfiltum
Are sure about your relevant equation ?
And the chute opens beyond the time shown on the t-axis, (as axmls already said), so don't even consider that.
What about the acceleration for small t ? and when t comes closer to T ?
Likes toforfiltum
So, when nearing T the diver almost reaches terminal velocity, that's why there's no more increase in air resistance. But after opening the parachute, why is the force still constant? I don't get that part of the graph.
It is constant and equal to the weight of diver.
Likes Dr. Courtney
[taps desk, looks at student intently]
The time T is NOT the point of opening the parachute. It is the time of reaching terminal velocity.
Likes Dr. Courtney
So , all the graphs are not very right, is it?
Yes, but I think I have given you enough hints. :wink:
Likes toforfiltum
Oh *facepalm*. thanks. That sentence did not register in my head.
Related to Variation of Force-time graph for person opening parachute
1. What is the force-time graph for a person opening a parachute?
The force-time graph for a person opening a parachute typically shows a sudden increase in force as the parachute opens, followed by a gradual decrease in force as the parachute slows down the person's descent.
2. What factors can affect the shape of the force-time graph for a person opening a parachute?
The shape of the force-time graph for a person opening a parachute can be affected by a variety of factors, including the size and type of parachute, the weight and size of the person, the air resistance, and the altitude and speed of the person's descent.
3. How does air resistance impact the force-time graph for a person opening a parachute?
Air resistance can significantly impact the force-time graph for a person opening a parachute. Higher air resistance will result in a longer and smoother force-time graph, as the person will experience more drag and a slower descent. Lower air resistance will result in a shorter and steeper force-time graph, as the person will experience less drag and a faster descent.
4. How does the size and type of parachute affect the force-time graph for a person opening a parachute?
The size and type of parachute can greatly impact the force-time graph for a person opening a parachute. A larger parachute will result in a longer and smoother force-time graph, as it will provide more drag and slow down the person's descent. A smaller parachute will result in a shorter and steeper force-time graph, as it will provide less drag and result in a faster descent.
5. Why does the force decrease after the parachute is fully opened?
The force decreases after the parachute is fully opened because the parachute is now providing enough drag to slow down the person's descent. As the person's speed decreases, so does the force exerted on the parachute. Eventually, the force will reach a steady state as the person reaches a constant speed during their descent.
