Variation of gravity along latitude
In summary: At a latitude of \theta not equal to zero or 90 degrees, g' still equals g, because at these latitudes, R omega square is zero.
wilsonlye
Factor contributes to variation of gravity along latitude is:
1. shape of the earth
2. rotation of the earth
gravitational field strength is resolved into two components, (R cos[tex]\theta[/tex])[tex]\omega[/tex] square, and g'
at the poles,[tex]\theta[/tex] =90 degree, therefore, g' = g which is 9.81
at the equator [tex]\theta[/tex]=0, therefore, g' = g- R omega square
what I couldn't understand is that why the components of g are not perpendicular to each other.
can we resolve a force into components which are not perpendicular to each other ?
Astronomy news on Phys.org
The components of g are not perpendicular because they come from two distinct sources.
Think of it this way: Consider a mass at rest on an inclined frictionless plane. A cable connects the mass to the top of a fixed pole which rises above the top of the plane. The forces on the mass include gravity (down), the normal force (normal to the plane), and tension (toward the top of the pole). None of these forces are perpendicular to one another.
then what are the two distinct sources?
one of them is R cos([tex]\theta[/tex])[tex]\omega[/tex]square
the other source?
[itex]R\omega^2\cos\theta [/itex] is not a source. It is a mathematical expression. What is the source of that term?
The other source is of course gravity itself. Where does it point?
g points towards the centre of the earth
that term is centripetal force
These are the directions of the two forces...
The force of gravity acts from the center of mass of earth and so intersects normal to the Earth surface (approximately) at any latitude, BUT...
Centrifugal force (from Earth rotation) acts perpendicular to the axis of rotation, and so it intersects at various angles at the (curved) surface depending upon latitude.
In another word, mg and centripetal force are two different forces act on a particle and mg' is the resultant force experienced by the particle?
Yes, basically; one arises from the gravitational mass (of earth) and the other from the rotating reference frame.
Creator
A side question...I've always wondered about the high jump in track being affected by the position of the moon.
Shouldn't the total gravitational affect on an individual be slightly less when the moon is directly overhead?
"The components of g are not perpendicular because they come from two distinct sources."
I'm confused by the above statement. "g" is gravitational field strength and comes from wherever gravity comes from! Single source if you will.
Also, I understand that at the equator Fn= Fg- mw^2 R, where I am taking g as a positive value, but what about at at a latitude of [tex]\theta[/tex] not equal to zero or 90 degrees?
Related to Variation of gravity along latitude
1. How does gravity change as we move towards the poles?
The force of gravity decreases slightly as we move towards the poles due to the centrifugal force caused by the Earth's rotation. This is because the Earth's shape is slightly flattened at the poles, making the distance to the center of the Earth slightly greater.
2. Is there a significant difference in gravity between the equator and the poles?
Yes, there is a small but measurable difference in gravity between the equator and the poles. This is due to the Earth's rotation and the shape of the Earth, which causes a slight change in the distance to the center of the Earth.
3. How does gravity vary along different latitudes?
The force of gravity is strongest at the poles and weakest at the equator. This is because the Earth's rotation causes a bulge at the equator, making the distance to the center of the Earth slightly greater.
4. Can changes in gravity along latitude affect the Earth's weather patterns?
While changes in gravity along latitude do not directly affect weather patterns, they can have an indirect impact on ocean currents and atmospheric circulation, which can influence weather patterns.
5. How do scientists measure variations in gravity along latitude?
Scientists use specialized instruments called gravimeters to measure small changes in the force of gravity at different latitudes. These measurements can also be obtained by using satellites and other remote sensing techniques.
