Variation of parameters and the constraint
In summary, Lagrange's method of variation of parameters allows for the substitution of functions for constants in order to simplify a differential equation. This is done by imposing a condition on the form of the two functions u and v. By adopting this relation, it makes solving the equation easier.
randybryan
52
I have already read one thread on Lagrange's method of variation of parameters and it was very useful, but I am still confused about the use of the constraint.
If the solution to the homogeneous second order equation contains two functions, with arbitrary constants:
y= Ay1 + By2
Lagrange replaces constants by unknown functions so the solution becomes
y=u(x)y1 + v(x)y2
Then my notes say that inserting this solution into the differential equation provides a relationship between u, v and f(x). (Where the 2nd order linear diff equation is a0y'' +a1y' +a0y = f(x) )
But since there are two functions we need a second relation (i.e. we want a single solution, not a family of solutions). Therefore we are free to provide a constraint on the form of u and v (provided it leads to a solution)
Then my notes say, observe that adopting the relation:
u'y1 + v'y2 = 0
will make things easier.
This is where I'm confused. I mean, I can see that it trivially makes things easier by simply removing half of the equation to solve, but how can it be justified? And why not make y1'u + y2'v = 0? Mentally I equate it to someone building a house, but leaving out the electrical circuitry because it would make the building process easier.
I should point out I'm tired and 'mathed' out. Got to that point where things that made sense before suddenly don't make sense.
Think of it as partially trying to make u and v behave as if they were constants, which was the original situation, when you obtained the general solution for the homogeneous part of your linear ODE; think about it, if they were indeed constant, u' would be 0, and so would be v'.
Ok thanks, I can see the logic behind that. Can constants still be treated as functions of x? Otherwise how can you justify momentarily treating u and v as constants?
Be careful! Notice the part where I say "partially". They're not actual constants, they are functions of x, but just forced to partially behave like constants with that additional equation that is introduced.
The way I understand this concept is, it is a condition we are FORCING to happen in order to be able to solve the differential equation. If we did not force this condition, it would be impossible to solve for the two unknown functions.
Ok thanks again, but one last question. By 'forcing' this condition are we discounting other possible solutions that may exist? I'm not saying we can find them without the constraint, but could there be other solutions?
Thats a good question. I will have to do some research to find out. :)
FAQ: Variation of parameters and the constraint
What is variation of parameters?
Variation of parameters is a method used in differential equations to find a particular solution given a general solution. It involves finding a set of parameters that will satisfy the general solution and using them to find a specific solution.
How is variation of parameters used in physics?
Variation of parameters is used in physics to find the trajectory of an object under the influence of different forces, such as gravity or friction. By setting up a differential equation that describes the forces acting on the object, variation of parameters can be used to find the specific path or motion of the object.
What is the constraint equation in variation of parameters?
The constraint equation in variation of parameters is an additional equation that is used to determine the parameters needed to find a specific solution. It is typically derived from the initial conditions of the problem or from physical constraints on the system.
Why is variation of parameters useful?
Variation of parameters is useful because it allows for the determination of a particular solution without having to solve the differential equation from scratch. It also allows for more flexibility in finding solutions, as it can be used for nonlinear or nonhomogeneous equations.
Are there any limitations to using variation of parameters?
Yes, there are limitations to using variation of parameters. It can only be used for linear differential equations and may not always be the most efficient method for finding a particular solution. In some cases, it may be more practical to use other methods, such as separation of variables or Laplace transforms.
