Variation of saturation photocurrent with intensity
In summary: Hi rude man (Nice nickname). Thanks for reply. The question is not about photodiodes. It is about photelectric experiment. The results of photoeectric experiment were explained by Einstein's photon model. The experiment completely follows photon energy model.So the higher number of photons per unit time is compensated by the ability of those higher-energy photons to liberate deeper-situated electrons.In summary, the experiment results follow the photon energy model.
enkriya
  1. 1. In photoelectric experiment, if anode potential w.r.t. cathode is increased, photocurrent first increases then becomes a constant, since all the photoelctorns ejected from cathode are collected at anode. If we increase the intensity of light at this point, the 'saturation current' increases because number of photons incident per unit time increases. Now the problem is, if we increase the frequncy now keeping the intensity constant, that would mean we are decreasing number of photons incident per unit time, which should result in reduction of current.
Number of photons per unit time = IA/hf .
It is clear that number of photons strking per unit time will decrease, and current must drcrease. However every textbook of physics that i have states that saturation photocurrent will not change when frequncy is changed but intensity is kept constant.
http://dronstudy.com/wp-content/uploads/2014/02/124.jpg
In this graph, frequencies are different but intensity is same. By my logic, saturation current should be different. But is shown to be same for all frequencies.
Any ideas/ solutions are welcome. Thankyou for your time.
Oh, OK, sorry. Gotta look into this more. Meanwhile, others will undoubtedly help.
Could you cite a reference saying what you said? In your graph, are you sure intensity is kept constant?
Another thought: The weakest photons will liberate electrons close to the outermost orbital only. But it takes higher-energy photons to lberate electrons with larger bonding energies. So the higher-energy photons liberate electrons not liberatable by the lower-frequency photons. So the lower number of photons per unit time is compensated by the ability of those higher-energy photons to liberate deeper-situated electrons.
Related to Variation of saturation photocurrent with intensity
1. What is saturation photocurrent?
Saturation photocurrent refers to the maximum current that can be produced by a photodetector when it is exposed to a high intensity of light. This occurs when all the available electrons in the detector have been excited to the conduction band, and the current reaches a plateau despite further increase in light intensity.
2. How does the saturation photocurrent vary with intensity?
The saturation photocurrent increases linearly with increasing light intensity up to a certain point, after which it reaches a plateau and remains constant. This is because the number of excited electrons reaches its maximum level, and any additional light intensity does not result in the generation of more current.
3. What factors affect the variation of saturation photocurrent with intensity?
The main factors that affect the variation of saturation photocurrent with intensity include the material properties of the photodetector, the wavelength of light used, and the temperature of the detector. For example, different materials have different absorption coefficients and bandgaps, which can affect the number of electrons excited by light.
4. Why is it important to understand the variation of saturation photocurrent with intensity?
Understanding the variation of saturation photocurrent with intensity is crucial for optimizing the performance of photodetectors. It allows scientists to determine the maximum current that can be produced under different light conditions and to select the most suitable materials and operating conditions for their specific applications.
5. Can saturation photocurrent be exceeded?
Yes, it is possible to exceed the saturation photocurrent by using a higher intensity of light. This can result in a phenomenon known as photocurrent overshoot, where the current briefly exceeds the saturation level before stabilizing. However, this can cause damage to the photodetector and is not recommended for normal operation.
  • Quantum Physics
  • Classical Physics
