Vector analysis and distributions
In summary, the conversation is discussing the values of delta and divergence in various cases. It is mentioned that in general, the value of delta for 1/r is -4pi times the delta distribution at the point r. The conversation then delves into the calculation of div(r/r^3) and how it diverges at the origin. The use of the divergence theorem is suggested to compute the delta distribution at the origin.
LagrangeEuler
717
In many books it is just written that ##\Delta(\frac{1}{r})=0##. However it is only the case when ##r \neq 0##. In general case ##\Delta(\frac{1}{r})=-4\pi \delta(\vec{r})##. What abot ##\mbox{div}(\frac{\vec{r}}{r^3})##? What is that in case where we include also point ##0##?
Likes Delta2
Direct calculation gives ##-2r^{-3}## if I do it right. it diverges at the Origin.
You can use the divergence theorem to compute what delta distribution it is around the origin. When you compute the surface integral you get a constant value no matter which surface you use (you can verify this with spheres pretty easily) and that implies a delta distribution at the origin. You can make this more rigorous depending on how you define a delta distribution
