Vector calculus identity format question
In summary, the conversation discusses an identity involving the Laplacian for a vector and its magnitude, and provides links to resources for further information. The speaker also mentions a potential approach for deriving the identity but suggests it may not yield a simple result.
kent davidge
933
56
I know there is an identity involving the Laplacian that is like ##\nabla^2 \vec A = \nabla^2 A## where ##\vec A## is a vector and ##A## is its magnitude, but can't remember the correct form. Does anyone knows it?
If you were so inclined you could set ##\vec{A}=|\vec{A}|\hat{n}##, then churn out how the Laplacian looks in terms of various derivatives of ##|\vec{A}|## and ##\hat{n}##. I don't think you will get anything pretty.
Likes kent davidge and vanhees71
There's a vector identity with the vector laplacian here:
https://mathworld.wolfram.com/VectorLaplacian.html
Related to Vector calculus identity format question
1. What is the vector calculus identity format question?
The vector calculus identity format question is a mathematical problem that involves manipulating vectors and their components using various identities and properties of vector calculus. It is commonly encountered in physics and engineering applications.
2. What are some common vector calculus identities used in this type of question?
Some common vector calculus identities used in this type of question include the dot product, cross product, vector triple product, and vector derivative identities. These identities allow for the simplification and manipulation of vector equations.
3. How do I approach solving a vector calculus identity format question?
The best approach to solving a vector calculus identity format question is to first identify the identities and properties that are relevant to the given problem. Then, use these identities to manipulate the given vectors and equations until a solution is reached. It is also important to pay attention to the direction and magnitude of the vectors involved.
4. Can you provide an example of a vector calculus identity format question?
Sure, an example of a vector calculus identity format question could be: Find the value of x that satisfies the equation (2x + 3y) * (4x - 5y) = 0, given that x = [1, 2, 3] and y = [4, 5, 6]. This question involves using the dot product identity to simplify the equation and solve for x.
5. How can I use vector calculus identities in real-world applications?
Vector calculus identities are commonly used in physics and engineering applications, such as calculating forces and moments in mechanical systems, determining electric and magnetic fields, and analyzing motion and trajectories. These identities allow for the manipulation and simplification of complex vector equations, making them essential tools for solving real-world problems.
