Vector Calculus Proof: Curl V = 0 -> V = grad phi
In summary: I'm guessing this is what you guys are getting at with the ##\int v \cdot dr## notation.So, if I can show this line integral is path independent, then I'm done. Now, how do I show this line integral is path independent? (I'm guessing through the conditions given to me about the curl of V being zero?).In summary, the problem asks to show that if the curl of a vector field is zero in all of three dimensional space, then there exists a scalar function ##\phi(x,y,z)## such that the vector field is equal to the gradient of this function. Several
Tsunoyukami
215
If ∇ x v = 0 in all of three dimensional space, show that there exists a scalar function ##\phi (x,y,z)## such that v = ∇##\phi##. (from Walter Strauss' Partial Differential Equations, 2nd edition; problem 11; pg 20.)
I'm not really sure where to begin with this problem. I asked a few of my friends in math and they all provided me with suggestions that are above my level (ie. using something called Poincare's Lemma which we haven't covered in any of my classes yet). My difficulty lies in proving this is true in the direction required.
I can easily show this is true in the reverse direction. If ∇##\phi## = v, then ∇ x v = 0. I can show this with relative ease by simply writing out each component explicitly. (I won't do this here, however, since that's not what the question is asking me to do). I'm not sure how to go in the reverse direction, however. Any help would be greatly appreciated
(Also, to put the problem into context: this problem is an assigned problem near the beginning of an introductory PDEs class that assumes a familiarity with vector calculus, basic linear algebra and ODEs.)
It also might be worth mentioning that I think we can assume ##\phi## is a "nice" function - that is, that it is continuous and twice differentiable. Thanks a bunch in advance for any nudges in the right direction.
Hint: Stokes' Theorem.
Likes 1 person
In the words of my pre-calculus teacher: "If you don't know what to do, do something!"
What do you know about the curl (stuff you can do to curls, for example) that might even vaguely be useful? I find, often, just listing my resources gives rise to a simple proof.
Edit: WN got there first. Too slow. :smile:
As a side note, Poincaré's Lemma seems like a fun way to do this, and a little more straightforward to do. I might have to try it from that angle in the morning. :biggrin:
Likes 1 person
Just from the definition I can write:
∇ x v = <## \frac{∂ v^{z}}{∂ y} - \frac{∂ v^{y}}{∂ z}##, ##\frac{∂ v^{x}}{∂ z} - \frac{∂ v^{z}}{∂ x}##, ##\frac{∂ v^{y}}{∂ x} - \frac{∂ v^{x}}{∂ y}##>
Where the notation ##v^{i}## refers to the ith component of v.
For this expression to be 0 we must have each component 0, which suggests that ##\frac{∂ v^{z}}{∂ y} = \frac{∂ v^{y}}{∂ z}## (and similar for the other components). I'm not too sure where to go from here following the "do something" approach.The approach of using Stoke's Theorem let's me say that if the curl of a vector field is zero then the vector field must be conservative and we know that a function f exists such that the gradient of f is this vector field. This approach seems way too easy and I love it. Is this all it is?
Suppose I didn't know Stoke's Theorem - where would I go from what I've done above to brute force out the answer (if this is possible)? Thanks a bunch guys!
EDIT: I may as well look up Poincare's Lemma myself - this assignment isn't due until next Monday so I have plenty of time to fool around with different approaches!
Well you have that ##\int _{S}(\nabla \times V) \cdot dA = \int _{\partial S}V\cdot dr = 0##. Thus the line integral of ##V## around any closed loop is zero. How can you then use this to construct a scalar field ##\varphi## such that ##V = \nabla \varphi##?
The Poincare Lemma directly gives you the result but the proof of the Poincare Lemma itself is extremely non-elementary and requires algebraic topology to motivate and setup so I wouldn't worry about it.
If you want to avoid Stoke's Theorem, then you have to construct your function f directly. Given v= (v1,v2,v3), we know that
[tex] f + A(y,z) = \int v_1 dx [/tex]
[tex] f +B(x,z) = \int v_2 dy [/tex]
[tex] f + C(x,y) = \int v_3 dz [/tex]
for some functions A, B and C (check that e.g. the first equation gives that df/dx = v1). If you can show that there exist functions A,B and C such that
[tex] \int v_1 dx - A(y,z) = \int v_2 dy - B(x,z) = \int v_3 dz - C(x,y)[/tex]
Then the function f is equal to all three of these. The existence of these functions will have to come about using the curl = 0 condition (and the differential equations that you wrote down from there).
I recall a theorem from vector calculus that states something along the lines of: if the line integral of a vector function ##V## around any closed loop is zero then this vector function is conservative which means that it can be written as the gradient of a scalar function. I suppose you are in essence asking me to prove this part,correct?
I would do something like this:
Select an arbitrary point (a,b) in the domain D and compute the line integral from this point (a,b) to another arbitrary point (x,y) (where (a,b) ##\neq## (x,y)) that is composed of one or more curves, at least one of which is horizontal (call this union of curves ##C_{1}##). Do the same thign for a separate curve except with one piece being vertical (call this union of curves ##C_{2}@@)##. Then the line integral over the combination of these two curves will be zero because they will form a closed loop (that is ##C_{1} U -C_{2}## is a closed loop). Because this loop has components that are horizontal and vertical we know how the function changes along these horiztonal and vertical lines and we should find that their sum (which should be the gradient of the scalar function) satisfies the conditions necessary.
I realize this is a rather rough sketch of my idea. I essentially would look at forming a closed loop that is composed of at least one part horizontal and one part vertical so that I could write v
= P i + Q j. I'll have to review the section on line integrals in order to come up with a more precise proof.
The idea is to show that if the line integral is zero around closed loops, then the line integral is independent of the path taken. The desired result will then follow suit.
Related to Vector Calculus Proof: Curl V = 0 -> V = grad phi
1. What is the curl of a vector field?
The curl of a vector field is a mathematical operation that measures the rotation or circular movement of a vector at each point in the field. It is represented by the symbol ∇ x and is defined as the cross product of the gradient operator and the vector field.
2. How is the curl of a vector field related to its gradient?
If the curl of a vector field is equal to 0, it means that the vector field is irrotational or has no rotation at any point. This also implies that the vector field can be expressed as the gradient of a scalar function, known as the potential function or potential energy.
3. What is the significance of curl V = 0 in vector calculus?
Curl V = 0 is a condition that indicates that the vector field V is conservative, meaning that it has a potential function. This is a fundamental concept in vector calculus and is used to solve various physical and mathematical problems related to vector fields.
4. How does one prove that a vector field satisfies the condition curl V = 0?
To prove that a vector field satisfies the condition curl V = 0, one must show that the cross product of the gradient of each component of the vector field is equal to 0. This can be done by using the properties of cross products and applying them to the equations representing the vector field.
5. Can the condition curl V = 0 be applied to all vector fields?
No, the condition curl V = 0 can only be applied to vector fields that are continuous and have a continuous first-order derivative. Additionally, the vector field must also satisfy certain boundary conditions. If these conditions are not met, the field may not have a potential function and the curl may not be equal to 0.
