Vector Component Words Problem,
In summary, the golfer is faced with a putt that is 13.5 feet exactly northwest of her ball's location. After hitting the ball straight but at the wrong angle of 40 degrees west of north, she needs to determine the angle and magnitude of the second putt in order to have a "two putt green." Effort is needed to work out the problem, such as drawing a graph and correctly representing the direction and magnitude of the first putt.
thaolieu
Vector Component Words Problem, please help :(
A golfer lines up for her first putt at a hole that is 13.5 exactly northwest of her ball’s location. She hits the ball 13.5 and straight, but at the wrong angle, 40 degree from due north.
a)In order for the golfer to have a “two putt green,” determine the angle of the second putt.
Angle= ? degree in south of west
b)Determine the magnitude of the second putt's displacement.
Welcome, thaolieu, to PF. The idea here is that if you show some effort at working out the problem then help can be provided. So I must ask you, what have you tried? Can you draw a picture of the situation? What are you confused about, etc.
I drew the graph that indicate the direction of the ball and putt #1.
Direction of the ball = -13.5x +0y
Putt 1 = 13.5 cos (40)x + 13.5sin (40)y = -3.16x + 8.67y
That's what I got. I hope to receive help to go further. Thank you so much
...but at the wrong angle, 40 degree from due north
This is a little ambiguous, let's agree that the golfer is a pretty good putter so this direction is really 40 degrees WEST of NORTH.
To start, your graph should contain 2 vectors: the location of the hole and the location of the ball after the first putt. Can you post your graph, with all the information, to make sure you are starting out correctly?
This is a location vector pointing WEST. Please recheck what you are trying to do here. Convention: +x = EAST, +y = NORTH
When you graph -3.16x + 8.67y, does it look right? Specifically, does the angle look like 40 degrees, or not? Does the magnitude = 13.5, or not?
a) To have a "two putt green," the golfer's second putt needs to be aimed in the opposite direction of the first putt, which was at a 40 degree angle from due north. This means the angle of the second putt should be 40 degrees south of west.
b) The magnitude of the second putt's displacement can be calculated using trigonometry. The first putt had a magnitude of 13.5, and the angle of the second putt is 40 degrees. Using the cosine function, we can calculate the magnitude of the second putt's displacement as 13.5*cos(40) = 10.3. Therefore, the golfer's second putt needs to have a magnitude of 10.3 in order to reach the hole in two putts.
FAQ: Vector Component Words Problem,
1. What are vector components and how are they used in word problems?
Vector components are the individual parts of a vector, which is a mathematical quantity that has both magnitude (size) and direction. They are often used in word problems to break down a vector into its horizontal and vertical components, making it easier to solve problems involving motion or forces.
2. How do you determine the magnitude of a vector using its components?
To determine the magnitude of a vector using its components, you can use the Pythagorean theorem. Simply square each component, add them together, and then take the square root of the sum. This will give you the magnitude of the vector.
3. Can vector components be negative?
Yes, vector components can be negative. This indicates the direction of the component, with a negative component pointing in the opposite direction of a positive component.
4. What is the difference between scalar and vector components?
Scalar components are simply the numerical values of a vector's magnitude and direction, while vector components are the individual parts of a vector that make up its overall magnitude and direction.
5. Are there any real-world applications of vector component word problems?
Yes, there are many real-world applications of vector component word problems. These include analyzing forces in physics, calculating velocity and acceleration in motion, and determining the direction and magnitude of a displacement in navigation.
