Vector Displacement and Magnitude
In summary, a dog walks 3.50m south, then 8.20m at an angle 39.4 degrees north of east, and finally 15.0m west.
waldvocm
76
A dog walks 3.50m south, then 8.20m at an angle 39.4 degrees north of east, and finally 15.0m west.
a) What is the magnitude of the dog's total displacement
b) What is the directionof the dog's total displacement where directly east is taken as zero degrees and counter-clockwise is positive?
I have found components of some of the vectors
Ax= 0 Ay= -3.50
Bx= 15? (I am not sure about this) By= -3.50
Cy= 0 Is Cx = 15?
Then I used the formula C= sqrt Cx^2 + Cy^2
Resulting in 15 meters as the magnitude of displacement. Which doesn't sound right to me since he must have passed his starting point along his route of 15 meters west.
I then Used the formula tan -1 (Cy/Cx) resulting in 0 for his direction.
Can someone please help?!?
You have not taken not account the second displacement. Resolve that into two components. That gives you the position of the second destination from x-axis. From that point reach the final destination and note down the position of the final destination.
Would I use the formula C=sqrt(Ax+Bx)^2+(Ay+By)^2
Resulting in a displacement magnitude of 16.55
Bx = 8.2*cos39.4.
By = ...?
Final position from y-axis is 15 - Bx
Final position from x-axis is ...?
Were my previous components correct? Or do I find them by taking Ax= Acos(angle)
Ay=Asin(angle)
The angle for A would be -90 since he is walking directly south resulting in components of
Ax=0
Ay=-3.50
Vector B is 39.4
Bx=6.34
By=5.20
Don't Ay and By have to be the same since the tail of vector B starts and the tip of vector A?
My components for C would then be
Cx=6.34
Cy=1.7
Is this correct?
No.
Cx = -15 + 6.34
Cy = 1.7
The final position from the y-axis would be 8.66
The final position from the x-axis 3.50+1.7=5.2?
So in vector notation the displacement is C=-8.66i + 1.7j
To find the magnitude of the dogs total displacement I would use the equation
C=sqrt(Ax+Bx)^2+(Ay+By)^2 Which equals 6.56
And the direction of the dogs total displacement, where directly east is taken as zero degrees and counter-clockwise is positive, I would use the equation
tan (Cy/Cx) Which equals -.003? Do I use tan-1(Cy/Cx) Which equals -11
Ok, so
Cx=-8.66
Cy=1.7 (I knew that I don't know why I put 5.2)
For the direction I then have -.003 and -11 degrees for answers I am assuming I should use tan-1. How do I know when to use tan-1 or tan?
Final answers...
a) 6.56m
b) -11 degrees
How did you get 6.56?
Angle should be in the counterclockwise. So...?
To find the magnitude I have the equation C=sqrt(Ax+Bx)^2+(Ay+By)^2
Which equals 6.56
From the starting point Cx = 8.66 and Cy = 1,7
Find the resultant of the these two components.
I am not sure what to do.
Do I add the two components? 10.36?
Or
C=sqrt(Cx+Cy) Isn't Cx=-8.66? So you can't take the sqrt.
I am confused
Cx and Cy are perpendicular to each other.So
C = sqrt(Cx^2 + Cy^2)
So, final answers...
a)8.83m
b)11 degrees
No. The angle is in the second quadrant.
θ should be ...?
168 degrees?
Is the magnitude correct; 8.83?
Yes.
Related to Vector Displacement and Magnitude
1. What is vector displacement?
Vector displacement is a measurement of the change in position of a point in space, represented by a directed line segment called a vector.
2. How is vector displacement calculated?
Vector displacement is calculated by subtracting the initial position vector from the final position vector, resulting in a vector that represents the change in position.
3. What is the difference between vector displacement and scalar displacement?
Vector displacement includes both magnitude and direction, while scalar displacement only includes magnitude. This means that vector displacement can be represented by a directed line segment, while scalar displacement is represented by a single value.
4. What is vector magnitude?
Vector magnitude is the length of a vector, representing its size or strength. It is calculated using the Pythagorean theorem, taking into account both the horizontal and vertical components of the vector.
5. How is vector magnitude related to vector displacement?
Vector magnitude is a measure of the size of the vector displacement. The greater the magnitude, the larger the change in position. However, vector magnitude does not provide information about the direction of the displacement, which is also important in understanding the full displacement of an object.
