Vector field flow over surface in 3D
In summary, the conversation discusses the calculation of the flow of a vector field over a surface defined by a specific equation and with a normal pointing away from the origin. The suggested method is to use Gaussian law, which leads to an integral equation. The solution involves calculating the flow through the surface using polar coordinates and the correct sign for the surface normal vectors. A question is raised about the use of the sign, but it is clarified that the chosen method is correct.
skrat
748
Calculate the flow of ##\vec{F}=(y^2,x^2,x^2y^2)## over surface ##S## defined as ##x^2+y^2+z^2=R^2## for ##z \geq 0## with normal pointed away from the origin.
The easiest was is probably with Gaussian law. I would be really happy if somebody could correct me if I am wrong and answer my question below:
Gaussian law: ##\int \int _O\vec{F}d\vec{S}+\int \int _S\vec{F}d\vec{S}=\int \int \int_{Body} \nabla\vec{F}dV## where I used notation ##O## for the circle.
Now ##\nabla\vec{F}= 0## therefore ##\int \int _O\vec{F}d\vec{S}+\int \int _S\vec{F}d\vec{S}=0## so all that remains is to calculate the floe through surface ##O##.
Using polar coordinates ##x=r \cos \varphi ## and ##y= r \sin \varphi## for ##z=0##. Than ##r_{\varphi } \times r_{r}=(0,0,-r)##
##\int \int _O\vec{F}d\vec{S}=-\int_{0}^{2\pi }\int_{0}^{R}r^{5} \cos^2 \varphi \sin^2 \varphi d\varphi dr##
That should be ##-\frac{\pi R^6}{96}##.
Question here: I am a bit confused weather I should use the other sign here ##r_{\varphi } \times r_{r}=(0,0,-r)## or is this the right one?
Gauß's Law is for all the surface normal vectors pointing away from the enclosed volume. So your idea is correct.
FAQ: Vector field flow over surface in 3D
What is a vector field flow over a surface in 3D?
A vector field flow over a surface in 3D refers to the visualization of how a vector field, which is a mathematical concept representing the direction and magnitude of a physical quantity, affects the movement of particles or objects over a three-dimensional surface.
How is a vector field flow over a surface in 3D represented?
A vector field flow over a surface in 3D is typically represented by arrows or lines, where the direction and length of the arrows or lines correspond to the direction and magnitude of the vector field at a particular point on the surface.
What are some real-life applications of vector field flow over a surface in 3D?
Vector field flow over a surface in 3D has many practical applications, such as in fluid dynamics, meteorology, and computer graphics. It can also be used in modeling the flow of air over an airplane wing or the flow of water in a river.
How is the flow of a vector field over a surface in 3D calculated?
The flow of a vector field over a surface in 3D is calculated using mathematical equations and algorithms. These calculations take into account the properties of the vector field, the surface, and any external forces that may be acting on the system.
What are some techniques used to visualize vector field flow over a surface in 3D?
There are several techniques used to visualize vector field flow over a surface in 3D, such as streamlines, pathlines, streaklines, and particle tracing. These techniques help to show the direction and magnitude of the vector field at different points on the surface and how particles or objects would move along these paths.
