Vector Geometry: Quadrangular Pyramid with Inner and Cross Products
OG in terms of OA, OB and OCIn summary, the problem involves finding the inner product \overrightarrow {OA}.\overrightarrow {OB}, which is equal to 1. The second question is unclear, but it seems to involve finding the coordinates of point F and E, and then using them to find the equation of a plane containing points A, E, and F. Finally, the problem requires expressing OG in terms of OA, OB, and OC.
devinaxxx
A quadrangular pyramid OABCD with square ABCD as the bottom. OA = 1, AB = 2, BC = 2 Also, OA perpendicular to AB, OA perpendicular to AD.
Question 1 : Find the inner product [itex] \overrightarrow {OA}.\overrightarrow {OB}[/itex] and the size of the cross product |[itex]\overrightarrow {OA}X\overrightarrow {OB}[/itex] |
2. Let E denote the point dividing the OD into 2: 3, and let F be the midpoint of OC. **Also A plane including three points A, E, and F and a point intersecting the side OB or its extension are defined as G**. At this time, express OG with OA,OB,and OC . can someone give me hint? thanks
I got the first question that the inner product is OA.OB=1
but the second question,
I don't understand where is G in the plane and what is the relation with A,E,F?
And why [itex] \overrightarrow {AG}= s. \overrightarrow {AE}+t. \overrightarrow {AF}.\overrightarrow {OB}[/itex] ??
I suspect this problem is most easily solved using coordinate geometry. Set
A=(0,0,0)
B=(0,2,0)
C=(2,2,0)
D=(2,0,0)
From part 1 of the question we have O=(0,0,1).
Part 2 of the problem is stated rather unclearly. It seems to be missing key phrases. But my best guess is that it wants you to do the following steps:
  1. calculate the coordinates of F as (O+C)/2
  2. calculate the coordinates of E as (3O+2D)/(3+2)
  3. find the equation of the unique plane through points A, E and F
  4. find the equation of the unique line that passes through O and B
  5. find the coordinates of the point G that is the intersection of the plane from step 3 and the line from step 4
FAQ: Vector Geometry: Quadrangular Pyramid with Inner and Cross Products
What is a quadrangular pyramid?
A quadrangular pyramid is a three-dimensional geometric shape that has a square base and four triangular faces that meet at a point called the apex.
What is vector geometry?
Vector geometry is a branch of mathematics that deals with the study of geometric objects using vectors. It involves using mathematical operations such as addition, subtraction, and multiplication to analyze and manipulate these objects.
What are inner and cross products?
In vector geometry, the inner product is a mathematical operation that takes two vectors as input and produces a scalar value as output. It represents the cosine of the angle between the two vectors. The cross product, on the other hand, takes two vectors as input and produces a third vector that is perpendicular to the original two vectors.
How are inner and cross products used in quadrangular pyramids?
The inner and cross products are used to calculate various properties of a quadrangular pyramid, such as its volume, surface area, and angles between its faces. They can also be used to determine if two pyramids are similar or congruent.
What are some practical applications of vector geometry and quadrangular pyramids?
Vector geometry and quadrangular pyramids have various applications in real-world scenarios, such as in computer graphics, architecture, engineering, and physics. They are used to model and design 3D objects and structures, analyze forces and motion, and solve geometric problems in different fields.
