Vector position, velocity, coordinates and speed
In summary, Homework Statement A particle initially located at the origin has an acceleration of vector a = 5.00j m/s2 and an initial velocity of vector v i = 8.00i m/s.
nerdalert21
31
a)Find the vector position at any time t (where t is measured in seconds). (Use the following as necessary: t.)
Find the vector velocity at any time t.
b)Find the coordinates of the particle at t = 2.00 s.
x=...m
y=...m
Find the speed of the particle at this time.
Not quite sure. Tried rf=ri+Vit+1/2at^2
Vf=Vi+at
For a) I plugged what i thought was right into the first equation above with ri=0i+0j because it is at the origin(see question) but the answer (8.00it+2.50jt^2) was wrong
Your answer to (a) looks fine to me. Why do you think it's wrong?
I would calculate the velocity of the object :
v(t) = [(8.00i)² + (5.00jt)²]^0.5 the i component remains constant where as the j component is accelerating from point of origin, so I am to assume that vj(0) = 0
and if you integrate v(t) from 0 to t you would get the position.
..or atleast this is how I understand the problem.
It's stated that you have to find the position vector as a function of time. you are correct writing R(0) = 0i + 0j , but this is for the displacement at time t = 0.
Think of this as a projectile motion in a gravitational field.
R here is a vector.
Your expression for v(t) is for the speed of the object, not its velocity. If you integrate it, you'd get the distance the object moved, not its displacement.
R here is a vector.
If you look more closely at what nerdalert21 wrote, you'll see i's and j's in the answer, which are the Cartesian unit vectors. (It would have helped a lot if the OP had used the typesetting features of the forum.) The answer ##\vec{r}(t) = (8.00t\,\hat{i} + 2.50t^2\,\hat{j})\text{ m}## is correct, so it's unclear why the OP thinks it's wrong. I'm guessing this is for web-based homework, and the OP somehow typed it in incorrectly.
I got a, I had messed up on typing the answer in.
For finding the vector velocity at any time t (a part2) can I use the equation Vf=Vi+at?
And then plug in the Vi, a and 0 for t?
Yes. You have the right idea for part 2, but they are asking for the velocity vector at an arbitrary time t, rather than at time t = 0.
Chet
Thanks for all your help guys, I've almost got the question done
The last part says to find the speed of the particle at time t=2
Thats solving for V right?
But I am confused on which equation i should use
You use your equation for the velocity vector evaluated at time t = 2, and then evaluate the magnitude of that vector to get the speed.
What do you mean by evaluate the magnitude?
Like, if i took the x and y components and put them like this:
R=√(x^2+y^2
Yup, but with the components of the velocity.
ok so for the velocity vector at any time t i got 8.00i+5.00jt
and the coordinates at t=2 are
x=16.00m
y=10.00m
So i tried the r=√16^2 + 10^2 and got 18.9 but it says the answer is wrong
Did i do that right?
Calculate the velocity vector at t=2 s. Then find the magnitude of that vector. ##\vec{r}## has nothing to do with the speed.
so i use Vf=Vi+at?
& I thought r is the magnitude?
Every vector has a magnitude and direction. If you're talking about the displacement vector, ##\vec{r} = x\,\hat{i}+y\,\hat{j}##, its magnitude ##r=\|\vec{r}\| = \sqrt{x^2+y^2}## would be the distance from the origin. If you're talking about the velocity vector, ##\vec{v} = v_x\,\hat{i}+v_y\,\hat{j}##, its magnitude ##v=\|\vec{v}\| = \sqrt{v_x^2+v_y^2}## would be the speed.
Likes 1 person
ohhh ok so it would be V=√(8^2+5^2)?
I figured it out :)
thanks for all your help!
Related to Vector position, velocity, coordinates and speed
1. What is a vector?
A vector is a mathematical quantity that has both magnitude and direction. It is often represented by an arrow, with the length of the arrow representing the magnitude and the direction of the arrow representing the direction.
2. What is position vector?
A position vector is a vector that describes the position of a point in space relative to a fixed reference point. It is often represented by the coordinates (x, y, z) of the point relative to the reference point.
3. How is velocity related to position vector?
Velocity is the rate of change of position over time. It is directly related to the position vector, as the direction and magnitude of the position vector determine the direction and speed of the object's motion.
4. What are coordinates?
Coordinates are a set of numbers used to specify the exact location of a point in space. In a 3-dimensional coordinate system, coordinates are often represented by (x, y, z) values, with x representing the horizontal position, y representing the vertical position, and z representing the depth position.
5. How is speed different from velocity?
Speed is a measure of how fast an object is moving, regardless of its direction. Velocity, on the other hand, is a vector quantity that not only includes the speed of an object, but also its direction of motion. In other words, velocity takes into account both the magnitude and direction of an object's motion, while speed only considers the magnitude.
