Vector Potential and Zero Divergence
In summary, the conversation discusses the possibility of a vector potential with zero divergence and the proof that it can be achieved through a gauge transformation. The relevant equation is B=∇χA and the Coulomb gauge is mentioned as a solution to this problem.
hellsingfan
I'm trying to understand when a vector field is equal to the curl of a vector potential. Why is it possible that there is always a vector potential with zero divergence?
Relevent Equation:
B=∇χA
I'm trying to understand the proof that the above vector potential A can be one with zero divergence.
We know that if we perform a gauge transformation [itex]A = A' + \triangledown \xi[/itex], where [itex]\xi[/itex] is an arbitrary scalar field, then both [itex]A'[/itex] and [itex]A[/itex] result in the same observed magnetic field i.e. [itex]B = \triangledown \times A' = \triangledown \times A[/itex] (and of course, as usual, we have to perform the associated gauge transformation of the scalar potential to keep the observed electric field the same).
Say we are given a vector potential [itex]A'[/itex]. We can find a [itex]\xi[/itex] that solves [itex]\triangledown ^{2}\xi = -\triangledown \cdot A'[/itex]. Performing the gauge transformation [itex]A = A' + \triangledown \xi [/itex] we see that [itex]\triangledown \cdot A = \triangledown \cdot A' + \triangledown ^{2}\xi = 0[/itex] hence we can fix this gauge (again, after performing the associated gauge transformation of the scalar potential) so that we have [itex]B = \triangledown \times A, \triangledown \cdot A = 0[/itex]. This is called the Coulomb gauge.
Thank You!
No problem!
FAQ: Vector Potential and Zero Divergence
1. What is vector potential?
Vector potential is a mathematical function used to describe the magnetic field in electromagnetism. It is defined as the curl of the magnetic field, and it helps to simplify calculations and equations in this field of study.
2. How is vector potential different from magnetic field?
While vector potential and magnetic field are closely related, they are different concepts. Vector potential is a mathematical construct that helps us understand and calculate the magnetic field, whereas the magnetic field is a physical quantity that describes the force exerted on a charged particle in a magnetic field.
3. What is the significance of zero divergence in vector potential?
Zero divergence is an important property of vector potential. It means that the vector potential has no sources or sinks, which is essential in the study of electromagnetism. It also helps us understand the behavior of electromagnetic fields and their interactions with charged particles.
4. How is vector potential used in practical applications?
Vector potential has various applications in different fields, such as engineering, physics, and geophysics. It is used in the design and analysis of electromagnetic devices, such as motors and generators. It is also used in the study of Earth's magnetic field and in medical imaging techniques, such as magnetic resonance imaging (MRI).
5. Is vector potential a physical quantity?
No, vector potential is not a physical quantity. It is a mathematical construct that helps us understand and calculate the magnetic field. However, it is a crucial concept in the study of electromagnetism and has many practical applications.
