Vector Potential of Spinning Sphere
In summary, the conversation discusses how to solve a problem involving a spinning shell using different methods. The first method involves tilting the sphere in the xz plane, while the second method involves trying it on the z-axis. Despite the mathematical calculations, it is determined that the second method will yield an answer of 0. However, by exploiting spherical harmonics and symmetry, a correct result can be obtained. The conversation concludes with appreciation for help and confirmation of the method's success.
Shinobii
34
I am just wondering, in Griffiths text, he solves this problem for a spinning shell. He states that the problem is easier if you tilt the sphere so it is spinning in the xz plane.
When solving for the current density, Griffiths writes,
(\omega \times r') =
\begin{vmatrix}
\hat{x} & \hat{y} & \hat{z} \\
\omega \sin(\psi') & 0 & \omega \cos(\psi') \\
r' \sin(\theta') \cos(\phi') & r' \sin(\theta') \sin(\phi') & r' \cos(\theta')
\end{vmatrix}
But suppose we want to try it on the z-axis such that,
\begin{vmatrix}
0 & 0 & \omega \\
\end{vmatrix}
Doing this however yields an answer of 0! Since,
\int_0^{2 \pi} sin(\phi') d\phi' = \int_0^{2 \pi} cos(\phi') d\phi' = 0
Does anyone have insight to if this problem is solvable using the second method? I ask this, because this is what I would do in an exam situation!
First, you might consider losing the determinant calculation. If you are at this level of mathematics, you might as well use linear algebra rather than a mnemonic, if not using the tensor definition of the cross product.
Define the cross product of two vectors, ##\vec{a}## and ##\vec{b}##, as ##\vec{a}\times\vec{b}=\left[\begin{matrix} 0 & -a_3 & a_2 \\ a_3 & 0 & -a_1 \\ -a_2 & a_1 & 0 \end{matrix}\right]\left[\begin{matrix} b_1 \\ b_2 \\ b_3 \end{matrix}\right]##, where ##a_i## is the ith component of the ##\mathbb{R}^3## vector ##\vec{a}##, with ##b_i## defined similarly.
Assuming that ##\omega## and r' are not scalar multiples of each other, the cross product should not reduce to the zero (probably not 0!=1 either) vector.
Hmm, mathematics aside (I completely disagree with you, the mnemonic is simple to understand physically, while tensor notation is required for more difficult problems (such as relativistic electrodynamics), this problem is rather simple) you will still get zero. I am not worried about my terms cancelling out, it is the integration that sets my answer to zero. . .
Ah, I see now that I can exploit spherical harmonics and symmetry which leaves me with the correct result! Since,
\sin(\theta')\cos(\phi') = - \sqrt{\frac{8 \pi}{3}}{\rm{Re}}[Y_{1,1}(\theta', \phi')]
Then by orthogonality everything should fall into place (I have not done this but I will do so right away and verify that it works).
Yep, this method works fine and dandy! Thanks again Mandelbroth, I appreciate you taking the time to reply.
The vector potential of a spinning sphere is a complex problem and there are multiple ways to approach it. It is true that the problem becomes simpler if you tilt the sphere so that it is spinning in the xz plane, as Griffiths suggests. This is because when the sphere is tilted, the angular velocity vector is no longer aligned with the z-axis, and therefore the cross product in the current density expression becomes non-zero.
However, attempting to solve the problem using the z-axis as the axis of rotation can also be done, but as you have observed, it yields an answer of 0. This is because the integral of sine and cosine over a full period is indeed 0. In this case, the solution is not physically meaningful as it implies that there is no magnetic field generated by the spinning sphere.
In an exam situation, it is important to carefully consider the given problem and choose the appropriate approach. In this case, it would be more appropriate to follow Griffiths' suggestion and tilt the sphere to simplify the problem. However, it is always good practice to understand the reasoning behind the suggested approach and to explore alternative methods of solving the problem.
Related to Vector Potential of Spinning Sphere
1. What is the concept of vector potential?
The vector potential is a mathematical concept used in electromagnetism to describe the behavior of magnetic fields. It is a vector quantity that represents the potential energy of a magnetic field at a certain point in space.
2. How does a spinning sphere have a vector potential?
A spinning sphere has a vector potential because it creates a magnetic field due to its rotation. This magnetic field can be described using the vector potential, which helps to understand the behavior of the magnetic field around the spinning sphere.
3. What is the relation between the vector potential and the magnetic field?
The vector potential and the magnetic field are closely related. The magnetic field can be calculated from the vector potential through the use of the curl operator. In other words, the vector potential is the mathematical quantity that describes the magnetic field.
4. How is the vector potential of a spinning sphere calculated?
The vector potential of a spinning sphere can be calculated using mathematical equations based on the properties of the sphere, such as its radius, angular velocity, and magnetic moment. This calculation involves vector calculus and can be complex, but it helps to understand the behavior of the magnetic field around the spinning sphere.
5. Why is the vector potential of a spinning sphere important?
The vector potential of a spinning sphere is important because it helps to understand the behavior of magnetic fields in different situations. It is a useful tool in electromagnetism and has applications in various fields such as engineering, physics, and geology. Additionally, understanding the vector potential of a spinning sphere can also aid in the design and optimization of magnetic devices.
