Vector problem(A+B=C) A and C given
  • Thread starter Frenchie
  • Tags
    Vector
In summary, to find the magnitude and angle of vector B in the equation A+B = C, where vector A has a magnitude of 10.6 m and is angled 41.3° counterclockwise from the +x direction, and vector C has a magnitude of 16.5 m and is angled 13.1° counterclockwise from the -x direction, you can use the Pythagorean theorem and trigonometric functions. To find the magnitude, you can use the fact that the sum of the components of A, B, and C must equal zero, and to find the angle, you can use the tangent function.
Frenchie
In the sum A+B = C, vector A has a magnitude of 10.6 m and is angled 41.3° counterclockwise from the +x direction, and vector C has a magnitude of 16.5 m and is angled 13.1° counterclockwise from the -x direction. What are (a) the magnitude and (b) the angle (relative to +x) of B ? State your angle as a positive number.
I found the components of vector A and C which came out to be
Ay=10.6*sin(41.3)=6.99601768
Ax10.6*cos(41.3)=7.963399815
Cy=16.5*sin(13.1)=3.739746573
Cx=16.5*cos(13.1)=16.0760346
so I'm not sure what i do after that. Do i add the components or subtract them to get By and Bx and then get the square root of both y and x squared? Thank you for any help given!~
Hello,
Thank you for your question. To find the magnitude and angle of vector B, you can use the Pythagorean theorem and trigonometric functions.
(a) The magnitude of vector B can be found by using the Pythagorean theorem: B = √(Bx^2 + By^2). To find the components of vector B, you can use the fact that the sum of the components of A, B, and C must equal zero. So, Bx = -Ax - Cx and By = -Ay - Cy. Substituting the values you calculated for Ax, Ay, Cx, and Cy, you can find the components of B and then use the Pythagorean theorem to find the magnitude.
(b) To find the angle of vector B, you can use the trigonometric function tangent. The tangent of an angle is equal to the ratio of the opposite side to the adjacent side. In this case, the angle you are looking for is the angle between vector B and the +x direction, so you can use the components of B to find this angle. The angle can be found by taking the inverse tangent (tan^-1) of By/Bx. Make sure to take the absolute value of this angle, as the inverse tangent function will give you a negative angle. This will give you the angle in radians. To convert it to degrees, you can multiply it by 180/π.
I hope this helps. Let me know if you have any further questions.
FAQ: Vector problem(A+B=C) A and C given
What is a vector?
A vector is a mathematical quantity that has both magnitude (size) and direction. It is typically represented by an arrow pointing in the direction of the vector with a length proportional to its magnitude.
How do you solve a vector problem with A and C given?
To solve a vector problem with A and C given, you can use the properties of vectors and basic vector operations such as addition, subtraction, and scalar multiplication. First, draw a diagram to visualize the problem and label the given vectors. Then, use the properties of vector addition to find the missing vector.
Can you solve a vector problem with only two vectors given?
Yes, you can solve a vector problem with only two vectors given as long as you have enough information to determine the missing vector. This can be done by using the properties of vector addition and subtraction, as well as trigonometric functions in some cases.
What are some real-life applications of vector problems?
Vector problems have many real-life applications in fields such as physics, engineering, and navigation. Some examples include calculating the velocity and acceleration of objects, determining the forces acting on a structure, and finding the direction and distance between two locations.
How can I check if my solution to a vector problem is correct?
You can check if your solution to a vector problem is correct by using the properties of vectors and basic vector operations. Make sure that the magnitude and direction of the missing vector match your solution. You can also use online vector calculators or ask someone to verify your solution.
