Vector product and vector product angles
In summary, the problem involves finding the angle between two vectors, A and B, given their scalar product of -6.00 and vector product of 9.00. By using the equations for scalar and vector products, we can determine that the angle between A and B is approximately 124 degrees. The reason why the angle between the scalar product and vector product gives us the angle between A and B is because the tangent of this angle can be calculated using the magnitudes of the vectors and the values of their respective products.
Bassa
46
Hello! I have a problem in my calculus based physics class regarding vectors. The problem says:
Vectors A and B have a scalar product -6.00 and their vector product has magnitude 9.00 what is the angle between these two vectors?
Here is how I approached it:
-6=|A||B|cos (theta)
9=|A||B|sin (theta)
tan (theta)= sin (theta)/cos (theta)
tan (theta)=9/-6=-56.31 degrees
since the sine is positive and cosine is negative the angle lies in the second quadrant.
180 degrees -56.31 degrees= 123.69 degrees which is approximately 124 degrees.
Now, why does the angle between the scalar product and the vector product of A and B give us the angle between A and B?
Thanks!
Scalar product is a number. There is no angle between a number and a vector...
Then how would I explain how I got the right answer?
|vector product| / |scalar product| gives you sin/cos, so the tangent. That is enough to extract the angle in ##[0, \pi]##
Thanks! That clarifies a lot of things. ^-^
Related to Vector product and vector product angles
1. What is a vector product?
A vector product, also known as a cross product, is a mathematical operation between two vectors that results in a third vector perpendicular to the original two vectors. It is represented by the symbol "×" and is defined as the product of the magnitudes of the two vectors and the sine of the angle between them.
2. How is a vector product calculated?
To calculate the vector product of two vectors, we use the following formula:
A × B = |A| |B| sinθ n
where A and B are the two vectors, |A| and |B| are their magnitudes, θ is the angle between them, and n is a unit vector perpendicular to both A and B. The result of the vector product is a vector that is perpendicular to both A and B.
3. What is the difference between a dot product and a vector product?
A dot product, also known as a scalar product, is a mathematical operation between two vectors that results in a scalar quantity. It is represented by the symbol "·" and is defined as the product of the magnitudes of the two vectors and the cosine of the angle between them. Unlike a vector product, the result of a dot product is not a vector but a number. Additionally, the dot product measures the similarity between two vectors, whereas the vector product measures their perpendicularity.
4. What is the significance of the angle between two vectors in a vector product?
The angle between two vectors in a vector product determines the magnitude of the resulting vector. The larger the angle between the two vectors, the larger the magnitude of the resulting vector will be. If the angle between the two vectors is 0 or 180 degrees, the result of the vector product will be 0, since the sine of these angles is 0. If the angle is 90 degrees, the resulting vector will be equal to the product of the magnitudes of the two vectors.
5. How can we use the vector product to find the area of a parallelogram?
The magnitude of the vector product of two vectors is equal to the area of the parallelogram formed by the two vectors. Therefore, we can use the vector product to find the area of a parallelogram by finding the magnitude of the resulting vector. For example, if we have two vectors A and B, the area of the parallelogram formed by these vectors would be |A × B|.
