Vector Subtraction: A^{→} - B^{→}
  • Thread starter defiledxhalo
  • Tags
    Vector
In summary, the problem involves calculating the vector difference A^{→} - B^{→} for two given vectors, A^{→} and B^{→}. The formula for calculating the resultant vector is used, which involves finding the x and y components of the vectors and then using the formula \sqrt{Rx^{2} + Ry^{2}}. The difference vector involves subtracting the x and y components of vector B^{→} from those of vector A^{→}. The final result is a vector with components Ax-Bx and Ay-By.
defiledxhalo
For the vectors [itex]A^{→}[/itex] and [itex]B^{→}[/itex], calculate the vector difference [itex]A^{→}[/itex] - [itex]B^{→}[/itex]. Magnitude of vector [itex]A^{→}[/itex] is 12 meters, with an angle of 180°. Magnitude of vector [itex]B^{→}[/itex] is 18 meters, with an angle of 37°.
[itex]A{y}[/itex] = Asinθ; [itex]B{y}[/itex] = Bsinθ
[itex]A{x}[/itex] = Acosθ; [itex]B{x}[/itex] =Bcosθ
Resultant vector = [itex]\sqrt{Rx^{2} + Ry^{2}}[/itex]
I know not providing a graph might make this problem a bit more difficult. I just really desperately need help on how to calculate vector subtraction because I'm not sure if I'm doing it right.
I found that the x-component of vector [itex]A^{→}[/itex] is -12 meters and the y-component is 0 meter. The x-component of vector [itex]B^{→}[/itex] is 14.4 meters and the y-component is 10.8 meters. From that, the [itex]R{x}[/itex] would be 2.4 meters and [itex]R{y}[/itex] would be 10.8 meters.
If I were to just do vector [itex]A^{→}[/itex] + [itex]B^{→}[/itex], I know how to calculate that. I would use the Resultant vector formula [itex]\sqrt{Rx^{2} + Ry^{2}}[/itex], which would give me of R = 11.06. But if I'm doing what this problem is doing, I don't know if that's the right formula to use.
I understand that [itex]A^{→}[/itex] - [itex]B^{→}[/itex] is the same thing as -[itex]B^{→}[/itex] + [itex]A^{→}[/itex]. I was wondering how the negative part translated into the calculation. For example, do I make vector [itex]B^{→}[/itex]'s x-component negative (to -14.4 meters), and have the [itex]R{x}[/itex] = -26.4 meters and the [itex]R{y}[/itex] = -10.8 meters (because vector [itex]B^{→}[/itex]'s y-component would then be -10.8 mters)? And if all that is correct, would I carry on with the same resultant vector formula [itex]\sqrt{Rx^{2} + Ry^{2}}[/itex], plugging in the numbers to get R = 28.5 meters?
Thank you so much for helping me!
The problem asks the vector difference, not only the magnitude of the difference vector. The components of the resultant difference vector are Ax-Bx and Ay-By.
ehild
FAQ: Vector Subtraction: A^{→} - B^{→}
1. What is vector subtraction?
Vector subtraction is the process of finding the difference between two vectors, represented by A^{→} and B^{→}. It involves subtracting the corresponding components of the vectors to find the resulting vector.
2. How is vector subtraction different from scalar subtraction?
Vector subtraction involves subtracting two vectors, which are quantities that have both magnitude and direction. Scalar subtraction, on the other hand, involves subtracting two scalars, which are quantities that only have magnitude.
3. What is the result of vector subtraction?
The result of vector subtraction is a new vector, represented by A^{→} - B^{→}. This vector represents the difference between the two original vectors, both in magnitude and direction.
4. Can vector subtraction result in a negative vector?
Yes, vector subtraction can result in a negative vector. This occurs when the resulting vector has a magnitude that is greater than the magnitude of the original vectors, but in the opposite direction.
5. How is vector subtraction used in science?
Vector subtraction is commonly used in science to calculate net forces, displacement, and velocity. It is also used in various fields of science, such as physics and engineering, to analyze the motion of objects and the forces acting upon them.
