Vector-valued function tangent
In summary, the conversation discusses how to show that a curve lies on a sphere with center at the origin if the position vector is always perpendicular to the tangent vector. The use of dot product and integration is suggested, and it is confirmed that the integrated right side becomes a constant, leading to the equation of a sphere.
Jonnyb42
186
If a curve has the property that the position vector r(t) is always perpendicular to the tangent vector r'(t), show that the curve lies on the sphere with center at the origin.
I know dot product might help:
r(t) . r'(t) = 0
and the equation of a sphere in 3-space:
r2 = x2 + y2 + z2
if I write out the components of the dot product...
r(t) . r'(t) = fx(t)*fx'(t) + fy(t)*fy'(t) + fz(t)*fz'(t) = 0
From there, I am not sure what to do, if that even is the right way to start.
What if you integrate both sides of your last equation?
Wow, how did you think of that?
It seems to work. The one thing I need help with is integrating the right side of 0, I think it's my lack of calculus knowledge. Does it become a constant?
I don't know - it just occurred to me because of those terms fx fx'.
Yes.
Thank you very much, just for completion's sake, I'll show the rest of the work:
It is easier to write functions with different letters, so from before, fx(t) will now be f(t), fy(t) will now be g(t), and fz(t) is now h(t).
[tex]\int f(t)df(t)[/tex] + [tex]\int g(t)dg(t)[/tex] + [tex]\int h(t)dh(t)[/tex] = [tex]\int 0dt[/tex]
[tex]\stackrel{1}{2}[/tex] f2(t) + [tex]\stackrel{1}{2}[/tex] g2(t) + [tex]\stackrel{1}{2}[/tex] h2(t) = C
f2(t) + g2(t) + h2(t) = r2 <-- form of a sphere.
FAQ: Vector-valued function tangent
What is a vector-valued function tangent?
A vector-valued function tangent is a mathematical concept that represents the direction and rate of change of a vector-valued function at a particular point. It is a vector that is perpendicular to the curve of the function at that point.
How is the vector-valued function tangent calculated?
The vector-valued function tangent is calculated by taking the derivative of the function with respect to the independent variable at the given point. This derivative is represented as a vector with components that correspond to the rates of change in each direction.
What is the significance of the vector-valued function tangent?
The vector-valued function tangent is important in many areas of science, including physics, engineering, and mathematics. It helps us understand the direction and speed of an object's motion, and can be used to predict future behavior.
How does the vector-valued function tangent relate to parametric equations?
A vector-valued function tangent is closely related to parametric equations, as both represent a curve in terms of one or more independent variables. In fact, the tangent vector can be calculated using the derivatives of the parametric equations.
What is the difference between a scalar-valued function tangent and a vector-valued function tangent?
A scalar-valued function tangent is a single number that represents the slope of a curve at a given point, while a vector-valued function tangent is a vector that represents both the direction and rate of change of the curve at a given point.
