Vectors and associated 2-forms
  • Thread starter JonnyMaddox
  • Tags
    Vectors
In summary: This is what Frankel calls a “pseudo-2-form”, and is not the same as a plain 2-form. In summary, in Frankel's book, he discusses the correspondence between vectors and (pseudo)-forms in R^{3} with cartesian coordinates. He explains that in general, this correspondence is not possible and one needs to use a metric to obtain covariant components. He also introduces the concept of a pseudo-2-form and proves that to a vector, one can associate a pseudo-2-form using the formula \beta^{2}= \iota_{\vec{v}}vol^{3}. However, this only works in Euclidean space and in general, one can only associate pseudo-forms to a vector
JonnyMaddox
74
In Frankel's book he writes that in [itex]R^{3}[/itex] with cartesian coordinates, you can always associate to a vector [itex]\vec{v}[/itex] a 1-form [itex]v^{1}dx^{1}+v^{2}dx^{2}+v^{3}dx^{3}[/itex] and a two form [itex]v^{1}dx^{2}\wedge dx^{3}+v^{2}dx^{3}\wedge dx^{1} +v^{3}dx^{1} \wedge dx^{2}[/itex], now in general this is not possible and you have to convert the components of a vector with a metric to get covariant components, for example like this [itex]v_{i}=g_{ij}v^{j}[/itex]
Then he asks what is in general the associated 2-form for [itex]\vec{v}[/itex] ? He then proofs that to a vector [itex]\vec{v}[/itex] one does associate a pseudo-2-form [itex]\beta^{2}:= \iota_{\vec{v}}vol^{3}[/itex] Later when he discusses the cross product he writes that one would like to say that [itex]v^{1} \wedge \omega^{1}[/itex] is the 2-form associated to the vector [itex]\vec{v} \times \vec{w}[/itex], but we only have a pseudo-2-form associated to a vector thus the pseudovector [itex]\vec{v} \times \vec{w}[/itex] is associated to the 2-form [itex]v^{1} \wedge \omega^{1}[/itex] (which is just a flip flop of words I think).
Now is it true that if we have other coordinates than cartesian, one can only associate pseudo-forms to a vector? Because in the text he calls the forms in cartesian coordiantes just forms, but in general he says pseudo-forms.
For example (everything in cartesian coord.) when I have a simple vector field [itex]v=3x \partial_{x}+4x \partial_{y}[/itex] then according to the formula [itex]\beta^{1}= \iota_{v}vol^{2}= 3xdy-4ydx[/itex] is the associated pseudo-1-form. Now what about the form [itex]\gamma^{1}=3x dx + 4y dy[/itex] isn't that the 1-form associated to the vector field? And [itex]\gamma^{2}= 3x dy \wedge dz+4y dz \wedge dx[/itex] should be the associated 2-form, but at the same time there should also be an associated pseudo-2-form [itex]3x dx\wedge dy -4y dx \wedge dz[/itex] according to the formula and if I calculated right. Now does this in general mean (none-cart.) that I have only pseudo-forms associated to vectorfields ??
I'm sorry you are not finding help at the moment. Is there any additional information you can share with us?
Possibly my answer will be too abstract, but you do not need Euclidean structure in three dimensions to have a correspondence between vectors and (pseudo)-2-forms. You need a weaker thing. Depending on how it deals with orientation, it may be called either volume form (that identifies vectors with 2-forms) or density (that identifies vectors with pseudo-2-forms). Euclidean/Riemannian metric induces a density, but one can’t recover the metric from a density only.
In other words, if in certain coordinates you see a familiar correspondence between vectors and pseudo-2-forms, you can’t be sure that these coordinates are not skew.
AFAIK, a pseudometric is enough to define a natural isomorphism between a space--say vectors here--and their duals, being the forms.
WWGD: you completely miss the point. You think about lowering an index: ωk = gkℓX. It makes an 1-form from a vector, and ιX ω = 1. It corresponds to scalar product (dot product in Euclidean space, or whatever, not necessarily positive-definite).
Original poster asks about ωjk = εjkℓX, a different thing making a 2-form from a vector. It corresponds to vector product in 3 dimensions and gives ιX ω = 0.
Related to Vectors and associated 2-forms
1. What is a vector?
A vector is a mathematical object that represents both magnitude (size) and direction. It is often used to describe physical quantities such as velocity, acceleration, and force.
2. How do you represent a vector?
In mathematics, a vector is typically represented by an arrow pointing in the direction of the vector with a length proportional to its magnitude. In physics, vectors are often represented by bold letters (e.g. v) or with an arrow on top (e.g. →v).
3. What is the difference between a vector and a scalar?
A scalar is a single value that has magnitude but no direction. Examples of scalars include temperature, mass, and time. A vector, on the other hand, has both magnitude and direction.
4. What is a 2-form?
A 2-form is a mathematical object that assigns a value to each pair of vectors in a vector space. It is often used in multivariable calculus and differential geometry to describe surface integrals and flux.
5. How are vectors and 2-forms related?
Vectors and 2-forms are related through the concept of duality. A vector can be thought of as a linear function that takes in a 2-form and returns a scalar value. Similarly, a 2-form can be thought of as a linear function that takes in two vectors and returns a scalar value.
  • Differential Geometry
  • Linear and Abstract Algebra
