Vectors and scalar projections
I'm not sure where you have learned this so I can't tell you where to find a proof. One way is to multiply the two sides of the equation by C and use the scalar triple product formula to get the proof.
hnnhcmmngs
Let a and b be non-zero vectors in space. Determine comp a (a × b).
comp a (b) = (a ⋅ b)/|a|
[/B]
comp a (a × b) = a ⋅ (a × b)/|a| = (a × a) ⋅b/|a| = 0 ⋅ b/|a| = 0
Is this the answer? Or is there more to it?
I don't know if your work is mathematically correct, but what can you say about the direction of the resultant of a x b compared to the direction of a? And what is the dot product of two vectors that have that directional relationship? :smile:
Likes hnnhcmmngs
[/B]
Your work is correct assuming that you have proven the formula that you can interchange dot and cross in a triple scalar product:$$
\vec A \cdot \vec B \times \vec C = \vec A \times \vec B \cdot \vec C$$
Likes hnnhcmmngs
Related to Vectors and scalar projections
What is a vector?
A vector is a mathematical quantity that has both magnitude (size) and direction. It is represented by an arrow, with the length of the arrow representing the magnitude and the direction of the arrow representing the direction.
What is a scalar projection?
A scalar projection is the component of a vector that lies in a specific direction. It is calculated by taking the magnitude of the vector and multiplying it by the cosine of the angle between the vector and the direction.
How is the scalar projection different from the vector projection?
The scalar projection only gives the magnitude of the component in a specific direction, while the vector projection gives both the magnitude and direction of the component. The vector projection is calculated by multiplying the scalar projection by the unit vector in the desired direction.
How is the scalar projection useful in real-world applications?
The scalar projection is useful in calculating work, force, and energy in physics. It is also used in engineering to determine the amount of force needed to move an object in a specific direction.
What is the difference between a dot product and a cross product?
A dot product is a scalar quantity that results from multiplying the components of two vectors, while a cross product is a vector quantity that results from multiplying the components of two vectors. The dot product gives information about the angle between the two vectors, while the cross product gives information about the perpendicularity between the two vectors.
