Vectors forming a parallelogram
In summary, a vector is a mathematical object with both magnitude and direction, while a parallelogram is a four-sided shape with equal and parallel opposite sides. Vectors can form a parallelogram by being placed head-to-tail, and the properties of this shape include parallel sides, equal angles, and angles that add up to 180 degrees. In real life, vectors forming a parallelogram can be used in fields such as physics, navigation, engineering, sports, and robotics for representing forces, calculating displacement and velocity, and analyzing motion.
shiri
85
The vectors 39.0 cm at 15.0° and 23.0 cm at 68.0° both start from the origin. Both angles are measured counterclockwise from the x axis. The vectors form two sides of a parallelogram.
a) Find the area of the parallelogram.
716cm^2
b) Find the length of its longer diagonal.
For b) is this question looking for the unknown length?
**update**
I found the answer
The wording you posted is odd since both diagonals of a parallelogram are equal. ARe you sure you copied the problem correctly?
for b) to be 50.5 cm based on the given information and using the law of cosines to find the length of the third side of the parallelogram.
FAQ: Vectors forming a parallelogram
What is a vector?
A vector is a mathematical object that has both magnitude (size) and direction.
What is a parallelogram?
A parallelogram is a four-sided shape with opposite sides that are parallel and equal in length.
How do vectors form a parallelogram?
To form a parallelogram, two vectors are placed head-to-tail, meaning the tail of one vector is placed at the head of the other. The resulting shape formed by the two vectors is a parallelogram.
What are the properties of a parallelogram formed by vectors?
The properties of a parallelogram formed by vectors include opposite sides that are parallel and equal in length, opposite angles that are equal, and consecutive angles that add up to 180 degrees.
How can vectors forming a parallelogram be used in real life?
Vectors forming a parallelogram can be used in real life to represent forces, such as in physics, or to calculate displacement and velocity, such as in navigation or engineering. They can also be used to model and analyze motion in various fields, including sports and robotics.
