Vectors in a Box: Find $\vec{AB}$ and $|AB|$
  • MHB
  • Thread starter karush
  • Tags
    Box
In summary, the conversation discussed a solid figure with six parallelogram faces and provided the coordinates of two points, A and B. The discussion then focused on finding the vector AB and its magnitude, with some corrections made for the calculation method. Further questions were mentioned to be addressed.
karush
MHB
3,269
The following diagram show a solid figure ABCDEFGH. Each of the six faces is a parallelogram
https://www.physicsforums.com/attachments/1034
The coordinates of $A$ and $B$ are $A(7, -3, -5), B(17, 2, 5)$
a) Find (i) $\vec{AB}$ and (ii) $|AB|$
$\vec{AB}=A+B=(24, -1, 0)$
$|AB|=\sqrt{(17-7)^2+(-3-2)^2+(-5-5)^2}=15$
was assuming that $A$ and $B$ have origin of zero.
there are $7$ more question to this problem but thot I would see if this starting out right since the rest of it is built on this.
Mathematics news on Phys.org
Re: vectors in a box
No, [tex]\displaystyle \begin{align*} \mathbf{AB} \end{align*}[/tex] is NOT [tex]\displaystyle \begin{align*} \mathbf{A} + \mathbf{B} \end{align*}[/tex]. Rather
[tex]\displaystyle \begin{align*} \mathbf{AB} &= \mathbf{AO} + \mathbf{OB} \\ &= -\mathbf{OA} + \mathbf{OB} \\ &= \mathbf{OB} - \mathbf{OA} \end{align*}[/tex]
You have found the magnitude correctly, but to write the vector $\vec{AB}$, you want to use:
\(\displaystyle \vec{AB}=\left\langle x_B-x_A,y_B-y_A,z_B-z_A \right\rangle\)
No, to work out the magnitude correctly it should either be [tex]\displaystyle \begin{align*} \sqrt{ (17 - 7)^2 + [2 - (-3)]^2 + [5 -(-5)]^2} \end{align*}[/tex] or [tex]\displaystyle \begin{align*} \sqrt{(7 - 17)^2 + (-3 - 2)^2 + (-5 - 5)^2} \end{align*}[/tex]. I realize that you get the same result, but the method is wrong.
Good catch...I should have said, "You have the correct magnitude" instead. Time for bed. (Sleepy)
so $\vec{AB} = \langle 17-7, 2+3, 5+5 \rangle = \langle 10, 5, 10 \rangle$
karush said:
so $\vec{AB} = \langle 17-7, 2+3, 0+5 \rangle = \langle 10, 5, 5 \rangle$
No, you want:
\(\displaystyle \vec{AB}=\langle 17-7, 2-(-3), 5-(-5) \rangle=?\)
Sweet dreams :)
MarkFL said:
No, you want:
there are 7 more ? on this
FAQ: Vectors in a Box: Find $\vec{AB}$ and $|AB|$
What are vectors in a box?
Vectors in a box refers to a set of two or three dimensional vectors that are contained within a specific region, or "box". These vectors can be represented by their starting and ending points, or by their magnitude and direction.
How do you find $\vec{AB}$?
To find $\vec{AB}$, you subtract the coordinates of point A from the coordinates of point B. This will give you the vector that starts at point A and ends at point B.
What is the significance of $\vec{AB}$?
The vector $\vec{AB}$ represents the direction and magnitude of the displacement from point A to point B. It can also be used to calculate the distance between the two points.
How do you find $|AB|$?
To find $|AB|$, you can use the Pythagorean theorem if the vector is two dimensional, or the magnitude formula for three dimensional vectors. This will give you the length or magnitude of the vector from point A to point B.
What is the difference between $\vec{AB}$ and $|AB|$?
$\vec{AB}$ represents a vector with both magnitude and direction, while $|AB|$ represents only the magnitude or length of the vector. They both provide different information about the displacement from point A to point B.
