MHB Vectors in Planes: Solving for m & n, Finding Orthogonal Plane
  • Thread starter Thread starter Lancelot1
    Planes Vectors
The discussion focuses on solving a high school math problem involving vectors and planes. The intersection point K(3.5,-0.5,-2) is given, along with the plane equation S1: mx-7my+5z+3=0 and the line l1: (n,1,-2)+t(-1,1,0). The parameters m and n were successfully determined as m=1 and n=2. The next steps involve finding the equation of a plane orthogonal to S1 that contains line l1 and calculating the area of a parallelogram formed by points on line l2 and point K. The discussion highlights the mathematical approach to derive the necessary equations for these tasks.
Lancelot1
Hiya,
I have a question in high school math, vectors to be precise:
The point K(3.5,-0.5,-2) is the intersection point of the plane S1: mx-7my+5z+3=0 with the line l1: (n,1,-2)+t(-1,1,0)
a) find the parameters n and m
b) find the equation of the plane that contains the line l1 and is orthogonal to the plane S1.
c) Another line is given, l2: (2,0,-1)+t(3,-3,0). Find the area of the parallelogram which has two vertices on l2 and to other vertices are K, and another point E(1,2,-2) which is on l1.
I managed to solve (a) and found that m=1, n=2 and t=-1.5.
I need your assistance with the other part of the question.
Thank you.
Mathematics news on Phys.org
Lancelot said:
Hiya,
Thank you.
a) To find the parameters $n$ and $m$, we can plug in the coordinates of the given point to the plane and the line:
$$m(3.5)-7m(-0.5)+5(-2)+3=0$$
Solving for $m$, we find:
$$m=1\quad\checkmark$$
$$n-t=3.5$$
$$t+1=-0.5$$
Adding, we obtain:
$$n+1=3\implies n=2\quad\checkmark$$
b) To find a plane, all we need is a point in the plane, and a vector perpendicular to the plane. Can you find those?
For (b) let the unknown plane be Ax+ By+ Cz= D. Since it is perpendicular to mx- 7my+ 5z+ 3= 0, its normal vector must be perpendicular to the normal vector of that plane: mA- 7mB+ 5C= 0. The fact that line (n,1,-2)+t(-1,1,0) lies in the plane means that A(n- t)+ B(1+ t)- 2C= D for all t. We already know that m= 1 and n= 2 so those equations become A- 14B+ 5C= 0 and A(2- t)+ B(1+ t)- 2C= 2A- At+ B+ Bt- 2C= (B- A)t+ 2A+ B- 2C= D for all t. Since that last equation is true for all t, corresponding coefficients must be equal: B- A= 0, 2A+ B- 2C= D.
We have the three equations A- 14B+ 5C= 0, B- A= 0, and 2A+ B- 2C= D. Normally, three equations would not be enough to solve for four unknowns, but we could always add or multiply Ax+ By+ Cz= D by a non-zero number to get another equation for the same plane. In particular, we can assume, say, that D= 1 so we have A- 14B+ 5C= 0, B- A= 0, and 2A+ B- 2C= 1, three equations to solve for A, B, and C.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
