Vectors - Projections and Components
In summary: R is the vector sum of F1 and F2 because their angles are 30 and 20 respectively. Their vectors are perpendicular to each other so the resultant is perpendicular to the b-axis.
Altairs
127
I am not sure if I am posting this in the right forum or not.
I had impression that there is just no difference between projection of a vector and its components until I took the Statics course. We are following The Engineering Mechanics : Statics book by Meriam and Krage. I got stuck up in the very beginning. the problem is that before this book, in elementary courses the trick of using costheta for projection and component worked very well. now it seems to be giving way.
In Sample problem 2/4 there are two forces at an agle of 50 to each other acting on a hinge. The question asks to find the projection of resultant on the line of force of the force making the lower side of parallelogram. Here, I took Rcostheta and the anser came wrong. the solution given is the Force(downward) + Force(upward)costheta(other). why didn't taking simply cos theta work when it would give the component in the direction of that force? Does it mean that components and projections aren't same always? How will I know what to do in a particular situation?
In contrast to above ,in another problem there is a 800lb force at 60 from an axis 'a' and the axis 'b' is at 135 from axis 'a'. In this case the projection is simply 800cos 60 while for component you have to make that parallelogram and that stuff. Why can't I simply find the component also by taking 800cos60 and 800cos75?
Why are the above two cases at 180 of each other?
I am very confused. And Statics is my Primary Course.
Altairs said:
I had impression that there is just no difference between projection of a vector and its components...
There is a big difference. The components of a vector are defined with respect to some basis.
Suppose [tex]\sigma_1[/tex], [tex]\sigma_2[/tex],[tex]\sigma_3[/tex] are a set of orthonormal basis vectors in 3D. Then any vector [tex]x[/tex] in 3D may be written in terms of these:
[tex]x = x_1\sigma_1 + x_2\sigma_2 + x_3\sigma_3[/tex].
The scalars [tex]x_i[/tex] are the rectangular components of the vector
[tex]x[/tex] with respect to the basis {[tex]\sigma_1,\sigma_2,\sigma_3[/tex]}. They are obtained from the dot product of the vector with the corresponding unit basis vector:
[tex]x_i = x\cdot \sigma_i = |x|\cos{(x,\sigma_i)}}[/tex]
The projection of vector [tex]x[/tex] onto some other vector [tex]b[/tex] is a vector:
[tex]x_b = (x\cdot b) b /|b|^2 = |x| \cos{(x,b)} (b/|b|)[/tex].
Notice that the magnitude of [tex]x[/tex] and of [tex]b[/tex] appear in
the definition of the projection. You could of course say that the
component of [tex]x[/tex] with respect to the unit vector [tex]b/|b|[/tex]
is [tex]|x|\cos{(x,b)}[/tex].
If you take the two forces 800cos 60 and 800cos 75, which you feel are components, would the resultant add up to 800, and would the angle of the resultant be at an angle of 60 deg from axis 'a'? You can try it out.
The projection of a vector F on any direction is always F(cos theta), where theta is the angle it makes with that direction.
If a force is a resultant of any two forces, then those two forces are the components of the former.
Just picture a simple case first. There are two forces P and Q, and R is the resultant. Then these forces P and Q are the components of R. P and Q need not be perpendicular to each other.
Suppose the angle between P and R is A and between P and Q is B. If you take the projection of R along the direction of P and Q, they are RcosA and Rcos(B-A). But these two don't, after vector addition, give back the resultant R, whereas P and Q do.
Since we generally use mutually perpendicular axes like the Cartesian axes, the projection on each axis and the components along the axes turn out to be the same.
But, this thing doesn't work on the first question with the resultant R. I'll post the whole question.
In the picture. There is a bracket on which two forces are acting. One is F1 (100N) at an angle of 30deg above the horizontal. Second, F2 (80N) is acting at an angle 20deg below horizontal.
The question reads :-
"Forces F1 and F2 avt on the bracket as shown. Determine the projection Fb of their resultant R onto the b-axis"
a and b-axis are the axis in which the forces F1 and F2 are acting.
this is an example, Page 31. Meriam, Krage
The answer should be (F2+F1*cos 50). How much did you get, and what is given as the correct answer?
Ya it is the answer. My question...Why doesn't Rcos20 give the required ans when, as you said that simply the cos theta gives the projection? This is exactly where my confusion lies.
Where did you get the totally wrong idea that the angle between R and b-axis was 20 deg? You have been the victim of a misleading diagram. If the resultant R were in the horizontal direction in the plane of F1 and F2, then R(cos 20) indeed would have given you the correct answer.
If R is the resultant of P and Q, then the projection of R in any direction is the sum of the projections of P and Q in the same direction. I have simply applied this rule. Are things clearer now?
ohhhhhhhh...I get it...Sorrrry...If I take the real angle and take cos then I'll get the answer...thanks...
Related to Vectors - Projections and Components
1. What is a vector projection?
A vector projection is a mathematical operation that involves finding the component of one vector that lies in the direction of another vector. It is essentially the shadow of one vector onto another.
2. How do you calculate the projection of a vector onto another vector?
The projection of a vector onto another vector can be calculated by finding the dot product of the two vectors and dividing it by the magnitude of the second vector. This will give you the magnitude of the projection vector, and then you can use basic trigonometry to find its direction.
3. What is the relationship between vector components and vector projections?
The components of a vector are the parts of the vector in the x, y, and z directions. The projection of a vector onto another vector can be thought of as the component of the first vector in the direction of the second vector. So, the vector projection is essentially finding the component of one vector in the direction of another.
4. Can a vector projection be negative?
Yes, a vector projection can be negative. This occurs when the angle between the two vectors is greater than 90 degrees. In this case, the projection vector will point in the opposite direction of the second vector, and its magnitude will be negative.
5. What are some real-world applications of vector projections and components?
Vector projections and components are used in many fields, including physics, engineering, and computer graphics. They are used to calculate forces and velocities in physics, to design structures and machines in engineering, and to create 3D graphics in computer graphics. They are also used in navigation and mapping systems.
