Vedic Math Method: Prove Conjecture Inspired by a Math Trick
  • MHB
  • Thread starter RLBrown
  • Tags
    Method
In summary, the conversation discusses a conjecture inspired by a math trick for division when the denominator ends in the digit 9. The concept is illustrated using an example and compared to the Vedic algorithm. It is noted that the Vedic math is neither Vedic nor math according to Wikipedia.
RLBrown
60
Below is a conjecture that I can't prove.
It was inspired by a math trick for division when the (base 10) denominator ends in the digit 9.
Can anyone help me out with a proof?
- - - Updated - - -
Here is an excell example,
Mathematics news on Phys.org
These numbers are the same that arise in the standard division algorithm (as taught in elementary school), like so:
[TIKZ]\draw (0,0) node {$5\,. {}^50{}^{12}0{}^60{}^30{}^{11}0\ldots$} ;\draw (0,-0.5) node{$0\,. {}^{\phantom5}2 {}^{\phantom{12}}6 {}^{\phantom6}3 {}^{\phantom3}1 {}^{\phantom{11}} 5 \ldots$} ;\draw (-2,-0.05) node {$19$} ;\draw (-1.7,0.3) -- (-1.7,-0.3) -- (1.6,-0.3) ;[/TIKZ]
At each stage of that algorithm, you carry forward a remainder $r_{k-1}$, multiply it by 10 and then divide by $10d-1$, getting a quotient $q_{k-1}$ and a remainder $r_k$, so that $$10r_{k-1} = (10d-1)q_{k-1} + r_k.$$ If you write that as $$r_k = 10(r_{k-1}- dq_{k-1}) + q_{k-1},$$ you see that it is exactly the same as the recurrence relation $$b_k = 10(b_{k-1} - da_{k-1}) + a_{k-1}$$ from the Vedic algorithm. (It also has the same initial condition $r_1 = n$.)
So if you believe the standard division algorithm, then you should also believe the Vedic algorithm.
FAQ: Vedic Math Method: Prove Conjecture Inspired by a Math Trick
What is Vedic Math and how is it different from traditional math?
Vedic Math is a mental math system that originated in ancient India. It differs from traditional math in that it uses unique techniques and strategies to solve mathematical problems quickly and efficiently.
Can you explain the Vedic Math method for proving conjectures?
The Vedic Math method for proving conjectures involves using a mathematical trick or shortcut to arrive at a solution. This method is based on the principles of Vedic Math and can be applied to various mathematical concepts and problems.
How can the Vedic Math method be useful in scientific research?
The Vedic Math method can be useful in scientific research as it allows for quick and accurate calculations, which can help in analyzing data and making predictions. It also promotes critical thinking and problem-solving skills, which are essential in scientific research.
Is there any evidence to support the effectiveness of the Vedic Math method?
Yes, there have been several studies and research papers that have shown the effectiveness of the Vedic Math method. Many students and professionals have also reported an improvement in their mathematical skills and problem-solving abilities after learning and practicing Vedic Math.
Can anyone learn and apply the Vedic Math method?
Yes, the Vedic Math method is suitable for people of all ages and backgrounds. It does not require any prior knowledge of Vedic Math or advanced math concepts. With practice and guidance, anyone can learn and apply the Vedic Math method to solve complex mathematical problems.
