tuscan440
- 3
hi there, i am currently developing a vehilce simulation model using MATLAB simulink. The simulation requires a vehilce to be simulated traveling around a simple race track. the vehilce model itslef has already been created and have all necessary vehicle input data for the simulation. the problem i have is that i have to simulate the vehicle approaching a corner from a straight line and decelerating at first 0.4g and then 0.8g, so that it travels around the corner at 10m/s. therefore i need to have a function that will determine the braking point relative to the stopping distance, (obviously the same as the distance to corner) and relative to velocity. as i have to perform a sensitivity analysis by changing other parameters the velocity will be different each time it is run so i need the function to determine the braking point by itself. is there any funtion you knwo where i can combine these two input parameters?any help appreciated
i have also posted in the coursework sectin as i was unsure which was most app.
