Velma and Mort relative motion question
In summary, Mort will observe Velma to be 20 years old when he dies, based on the time dilation factor of 1.5 at a speed of 0.75c. In the second conversation, the correct answer is E, as dropping a coin inside a smooth-flying jet would result in the coin landing to the rear of the drop point due to the acceleration of the plane. This allows for detection of the acceleration without relying on anything outside of one's own reference frame.
kirsten_2009
137
1. Velma passes Mort at a speed of 0.75c. At this speed, the "time dilation factor" is 1.5. In other words, Mort observes a 1-second tick of Velma's clock to take 1.5 seconds. Suppose that they are born at the same time, and that Mort observes himself to live 30 years. As Mort dies, how old will he observe Velma to be?
A.) 45 years
B.) 30 years
C.) 20 years
D.) 10 years
E.) 40 years
2. Suppose that you are inside a smooth-flying [no bumps] jet plane that is speeding up along a straight line. Can you detect this acceleration without directly or indirectly making use of anything outside of your own reference frame? If so, how could you observe this; and if not, why not?
A.) No, because of the principle of relativity.
B.) No, because of the principle of the constancy of lightspeed.
C.) No, because jet planes move far too slowly for such an effect to actually be observed.
D.) Yes. For example, if you dropped a coin you would find that it lands to the front of the drop point.
E.) Yes. For example, if you dropped a coin you would find that it lands to the rear of the drop point.
1. (C) -I'm not exactly sure why...
2. (D) -Just makes sense to me...
Thank you!
1. C is correct. You should do the math so that you see exactly why. If you don't know how to do the math, figure it out. Don't guess.
2. No, it's not D. The generally idea of your answer is right but how do you figure the coin would move FORWARD? Does your body tend to move forward as a jet takes off? Does it tend to move forward, away from the seat back, when you accelerate your car?
EDIT: Oh, perhaps you are thinking of dropping a coin OFF of the plane. Then it WOULD land to the rear, but that's cheating. If you can look out the window, you KNOW you are accelerating. I don't think that's intended as part of the problem.
Related to Velma and Mort relative motion question
1. What is relative motion?
Relative motion refers to the movement of an object in relation to another object. It takes into account the frame of reference and the perspective of the observer.
2. Who are Velma and Mort in the relative motion question?
Velma and Mort are two fictional characters used in a common physics problem to demonstrate relative motion. They are often referred to as "Velma and Mort relative motion question."
3. What is the scenario in the Velma and Mort relative motion question?
The scenario involves Velma, who is walking in a straight line at a constant speed, passing by Mort, who is standing still. The question typically asks about the relative motion between Velma and Mort.
4. How is the relative motion between Velma and Mort affected by the frame of reference?
The relative motion between Velma and Mort can appear differently depending on the frame of reference. For example, to Velma, Mort may appear to be moving backwards, but to an observer on the side, Mort may appear to be standing still.
5. What is the importance of understanding relative motion in physics?
Understanding relative motion is crucial in physics as it helps us understand how objects move in relation to each other and how different frames of reference can affect our perception of motion. It is also essential in calculating velocities and predicting the movement of objects in different scenarios.
