Velocity after collision and Kinetic Energy.
In summary, a trolley of mass 0.5 kg collides with a stationary trolley of mass 1.0 kg on a frictionless ramp. According to the principles of conservation of momentum, the total momentum before and after the collision remains the same. The first trolley rebounds with a speed of 2.0 m/s, causing a momentum change in the opposite direction. The velocity of the second trolley after the collision is -2.0 m/s. The collision is inelastic as kinetic energy is lost.
Meezus
57
A trolley of mass 0.5 kg rolls along a level, frictionless ramp at a velocity of 6.0 m s-1. It collides with a second trolley of mass 1.0 kg which is initially at rest. The first trolley rebounds with a speed of 2.0 m s-1 .
a) Stating clearly any principles involved, find the velocity of the second trolley after the collision.
b) Compare the kinetic energy before and after the collision. Is the collision elastic?
p = m x v
E=1/2*m*v^2
Momentum before collusion for carriage A: 0.5 x 6 = 3
Momentum before collusion for carriage B: 1 x 0 = 0
Total Momentum before : 3 + 0 = 3.
Total Mass = 1 + 0.5 = 1.5.
p = m x v
v = p / m
3 / 1.5 = 2.
The principles involved are that as long as no external forces are acting on the object the total momentum stays the same in a collisions.
Is this correct for the first one?
part b:[/B]
0.5 x 1.5 x 62 = 27
0.5 x 1.5 x 22 = 3
The collision is inelastic as kinetic energy is lost?
What is meant by "rebounds"?
Like when you throw a ball at a wall and it comes back. It "rebounds" off wall.
So the two bodies do not stick together.
Then try to complete this table, too:
Momentum after collision for carriage A:
Momentum after collision for carriage B:
Total Momentum after collision:
I thought because momentum is conserved the total momentum is the same after?
It should be. Can you fill in the blanks?
Momentum after collision for carriage A: 0.5 x 2 = 1
Momentum after collision for carriage B:1 x ? = ?
Total Momentum after collision: 3
If the total momentum stays the same the velocity for carriage B must be 2.
If a body rebounds, its velocity changes direction.
Ok. Is what I have done correct? I don't see where the rebound part comes into play?
Velocity and momentum are vectors. Direction matters. If a ball hits a wall square on at velocity v and rebounds with the same speed, what is its new velocity?
total momentum is conserved.
total momentum before collision = total momentum after collision
(if there is no external unbalanced force is acting there! )
The correct answer is 0.5 x -2 because rebound velocity is in the opposite direction. Momentum is a vector quantity.
Related to Velocity after collision and Kinetic Energy.
1. How is velocity calculated after a collision?
After a collision, the final velocity (Vf) can be calculated using the formula Vf = (m1 x v1 + m2 x v2) / (m1 + m2), where m1 and m2 are the masses of the objects involved in the collision and v1 and v2 are their initial velocities.
2. What is the conservation of momentum in relation to collision?
The law of conservation of momentum states that the total momentum of a closed system remains constant before and after a collision. This means that the sum of the momentums of the objects involved in the collision will remain the same, regardless of any changes in velocity or direction.
3. How does kinetic energy change after a collision?
The total kinetic energy of a system is also conserved in a collision, meaning that the sum of the kinetic energies before the collision will be equal to the sum of the kinetic energies after the collision. However, the kinetic energy of individual objects may change due to changes in velocity.
4. What is an elastic collision?
An elastic collision is a type of collision where the total kinetic energy of the system is conserved. This means that the objects involved in the collision bounce off each other without any loss of energy. In an elastic collision, the objects also conserve both momentum and velocity.
5. How does the mass and velocity of an object affect its kinetic energy?
The kinetic energy of an object is directly proportional to its mass and the square of its velocity. This means that an object with a larger mass or a higher velocity will have a greater kinetic energy. Conversely, a decrease in mass or velocity will result in a decrease in kinetic energy.
