Velocity after force applied for 0.01 s
In summary: The ball starts at A and the stick applies a force of 10N for 0.01 seconds. So the impulse transferred is 10*0.01=0.01kgm/s.
Anjum S Khan
A ball(1kg) at rest was hit by a stick to set it in motion. Assuming Force (10N) was applied by a stick, and stick remained in contact with the ball for 0.01s. Ball moves from A to B (10m) in time t.
Find,
a) Velocity at B ?
b) Time t ?
(assume frictionless surface)
F = ma, V = U + aT, V2 = U2 + 2as
a = F/m = 10N/1kg = 10ms-2, how to proceed after this ?
Find,
a) Velocity at B ?
b) Time t ?
i think for such short duration force acting the concept of impulsive force and its effect on the state of motion/rest must be considered.
You know the acceleration and you know the amount of time that the force is applied. So, what is the velocity after acceleration stops?
Velocity will be V = 10*0.01 = 0.1ms-1.
Now, this velocity will be come initial velocity for motion A to B.
And since surface is frictionless, so
Vb = Ua = 0.1ms-1.
And as velocity will be constant from A to B, so t = AB/Ua = 10m/0.1ms-1 = 100sec.
Likes CWatters and Chestermiller
Let's visualise what's happening
The stick remains in contact with the ball for 0.01 seconds
So the impulse transferred equals force exerted times the duration=0.1kgm/s
Now before contact , as the ball was initially at rest
The velocity of the ball when it loses contact with the bat/stick
Equal to 0.1/1=0.1m/s
Therefore this becomes your initial velocity of travel
Now remember that the 10N force no longer acts and thus there is no acceleration and due to the surface being frictionless, the ball moves with a constant velocity of 0.1m/s
When the distance is divided by this, we get the time taken
Which equals 10/0.1=100 seconds!
Your approach is absolutely correct!
UchihaClan13
Likes drvrm and Anjum S Khan
In Physics Forums, if you want to thank someone, all you need to do is check the "like" icon on the bottom of one of their posts. It's much less effort than writing a separate post.
If the ball starts at A then the answer should probably state that the duration of the acceleration phase is << than the coasting phase so it's effect on the time is negligible and can be ignored. It's not always true.
Related to Velocity after force applied for 0.01 s
1. What is the formula for calculating velocity after a force is applied for 0.01 seconds?
The formula for calculating velocity after a force is applied for 0.01 seconds is v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time interval.
2. How does the duration of the force application affect the velocity?
The duration of the force application affects the velocity by directly impacting the acceleration. The longer the force is applied, the greater the acceleration and therefore the higher the final velocity will be.
3. Is the velocity after force applied for 0.01 seconds the same as the average velocity during that time?
No, the velocity after force applied for 0.01 seconds is not necessarily the same as the average velocity during that time. The average velocity takes into account the initial and final velocities over a longer time interval, while the velocity after force is only calculated for a brief moment in time.
4. What units are used for velocity after force applied for 0.01 seconds?
The units for velocity after force applied for 0.01 seconds depend on the units used for initial velocity and acceleration. However, some common units include meters per second (m/s) or kilometers per hour (km/h).
5. How does the mass of an object affect the velocity after force is applied for 0.01 seconds?
The mass of an object does not have a direct effect on the velocity after force is applied for 0.01 seconds. However, it does impact the acceleration, which in turn affects the final velocity. A larger mass will require a greater force to achieve the same acceleration as a smaller mass.
