Velocity and Acceleration homework
The acceleration of point A is given by a = -1.8sin(3t), and the initial conditions are x = 0 and v = 0.6 m/s at t = 0. The integration of the acceleration equation leads to the expression v - v0 = 0.6cos(3t). When substituting v0 = 0.6 m/s and evaluating at t = 0.5s, the calculated velocity is v = 0.6424 m/s. However, the textbook answer is 42.4 mm/s, suggesting that the initial velocity should not be included in the integration.
srh
The acceleration of point A is defined by the relation a=-1.8sin(kt), where a and t are expressed in m/s^2 and seconds, respectively, and k=3 rad/s. Knowing that x=0 and v=0.6m/s when t=0, determine the velocity of point A when t=0.5s.
a=dv/dt
a dt = dv
a=-1.8sin(3t)
I began by using the equation a dt=dv. I substituted -1.8sin(3t) in for a. After integrating both sides I got v-v0=0.6cos(3t). I plugged in 0.6 m/s for v0. For t=0.5 I got v=.6424 m/s. The answer in the back of th book was 42.4mm/s. If I left v0 as zero, I would get that answer. But I thought I needed to include that. Am I missing something?
a=dv/dt
a dt = dv
a=-1.8sin(3t)
Think about the highlighted text. What function of the form v = f(t) is going to give you v0=0.6m/s?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
