- 726
- 166
This is for a junior level classical mechanics course. We're currently working with Newton's Laws.
A particle of mass m moves under the influence of a force ##\vec{F}(t,v)=-ktv \hat{v}##, where k is a positive constant. At time t=0, ##v=v_0 \hat{x}## at the origin, where ##v_0## is a positive constant.
a. Calculate the velocity of the particle ##\vec{v}(t)## for times t>0.
b. How much time does it take for the particle to stop?
c. What is the maximum x-position reached by the particle? Hint: you will need to look up ##\int_{0}^{\infty} (something) dt## on Wolfram Alpha, which is a tool that you should take the time to learn how to use!
$$\vec{F}=m \frac{dv}{dt}$$
For part a I figured that since F=m dv/dt, I could simply rewrite this as
$$-ktv \hat{v}=m \frac{dv}{dt}$$
And then solve for v
$$\frac{dv}{dt}=\frac{-ktv \hat{v}}{m}$$
$$\int{dv}=\int{\frac{-ktv \hat{v}}{m}}dt$$
$$\int{dv}=\frac{-kv \hat{v}}{m} \int{t}~dt~\hat{v}$$
So,
$$v=-\frac{kv~\hat{v}}{2m}t^2+v_0 \hat{x}$$
Where ##v_0 \hat{x}## is the constant of integration evaluated at time t=0.
Then for part b, I used this equation and set v=0, and arrived at
$$t=\sqrt{\frac{2v_0m}{kv}}$$
This seemed okay to me, but for part c it specifies that we're going to want to look up an integral. Obviously I can integrate velocity to obtain position, but the simplicity of the integral, along with the recommendation to use Wolfram Alpha, makes me think I'm doing something wrong. If anyone has any input, it would be greatly appreciated.
