Velocity and the human experience
In summary: sticking in our consciousness like it does with things like heights, we don't realize how fast we are going most of the time.
jeanpinto844
TL;DR Summary: Velocity and the human experience
As I was walking into work this morning I looked up and noticed an airplane flying overhead. Airplanes travel at speeds of up to 550 miles per hour while in flight. This question is really less about physics and more about our everyday experience with speeds. We experience speeds of up to 70-80 miles per hour perhaps in a car, on a train, or on a roller coaster as well as seeing objects travel at these speeds and yet when we look at an airplane it sure doesn't seem like it's going 550 miles per hour.
Do you think that physiologically, there is an upper limit to how we perceive high speeds? In other words, once we reach say, 150 miles per hour, any speed beyond that doesn't seem any faster so 500 miles per hour is the same experience as 150 miles per hour.
My apologies if this question seems out of place but I thought it to be interesting. Thank you.
We are very bad at judging speeds of distant objects. Particularly something like an aircraft on a featureless blue background, it's incredibly easy to see it as a small thing drifting along little more than just out of reach, and not a really large thing racing along several miles away. I guarantee that if it passes over you at 500mph you'll notice its speed is high! There are quite a few videos of low passes overhead by fighter aircraft on YouTube if you look. Or videos of carrier operations - the speed at which a large hunk of metal on the deck turns into a speck in the distance is quite remarkable.
Likes BillTre and pinball1970
It is interesting and is a question of biology as much as physics.
We evolved to interact our visual environment at shorter distances that included lions, mates, rivals, prey and a nearby place to hide not high-speed planes.
It is difficult to judge velocities and sizes at that distance unless you are trained, so our brains are easily fooled as Ibix said.
A good example is a wind turbine, have you ever been up close to one? Shocked at the size? Speed of the blades?
They look a lot smaller and slower from a distance, smaller and slower than you guessed till you are close.
Likes russ_watters and BillTre
No. There are often fighter jets practising in various mountain locations in the UK. I would estimate their ground speed at ##500 m/s## , which is over ##1,000## mph. They are definitely going faster than ##150## mph.
Likes pinball1970 and BillTre
I've seen little evidence that humans are practically competent at evaluating risks/consequences of speed, and that includes myself, a former drag racer, except in retrospect, or after large amounts of experience.
Simplistically, if you hang over a ledge, 25 feet (7-8m) over the ground, you have a risk of a ~30mph collision with the ground. Many people are afraid, or at least wary, of heights, even 5-10' (1.5-4m) or so. We (humans) are pretty good at understanding this risk, and tend to avoid it, and most don't hang off ledges 25' above the ground.
Yet, people will drive down the interstate at 75mph...often while doing things that could cause them to crash.
Neglecting airbags, restraints, and modern vehicle controls, the risk for harm when at highway speeds can be a factor of 6 greater than hanging off a second story balcony. Yet, most, like me, fear the balcony.
Likes russ_watters
Because the speed is not being experienced 'up close'.
Take the doors off and the floor board so people could see the ground up close move, and they would, perhaps, (not everyone would be as scared to poop), reduce the speed to a more 'comfortable' level.
Being enclosed within does not render how fast everything is moving by.
In a analogous situation, most people I presume, can walk on a chalk line on a floor with little apprehension.
Move the line up a bit, such as on a rail that a train follows, a mere distance of 5 or so inches, and the walk becomes less effortless - arms waving and feet feeling for support.
Or peer out full size window on a tall building - no problem. Remove the window glass and few would come up to inches of the ledge.
Or because it is not being felt/perceived.
The presence of safety equipment to moderate the perception of speed, reduce vibration, etc., definitely hides some of this.
May be part of why speed perception in a boat, or an open cart, seems so much greater than in an enclosed car, or why a rattle-trap vehicle at 30mph is far scarier than a silent car at 50.
Also, probably why wooden roller coasters can be as scary as they are.
Likes 256bits
FAQ: Velocity and the human experience
What is the definition of velocity in the context of physics?
Velocity is a vector quantity that refers to the rate at which an object changes its position. It is defined by both the speed of the object and the direction in which it is moving. Mathematically, velocity is the derivative of position with respect to time.
How does velocity affect human perception of time?
Velocity can influence human perception of time in various ways. For example, when traveling at high speeds, such as in a fast-moving vehicle, people often report that time seems to pass more quickly. This phenomenon is partly due to the relative motion and the reduced number of visual or environmental cues that can be processed in a given time frame.
What role does velocity play in sports and physical activities?
Velocity is crucial in sports and physical activities as it affects performance and outcomes. For instance, in running, swimming, or cycling, higher velocities generally lead to better performance. In team sports like soccer or basketball, the velocity of the ball and players can significantly influence the dynamics of the game and the effectiveness of strategies.
How does the human body adapt to high velocities?
The human body can adapt to high velocities through various physiological and biomechanical mechanisms. For example, the vestibular system in the inner ear helps maintain balance and spatial orientation. Muscles and joints also adapt by becoming more efficient in movement and coordination. Training and conditioning can improve the body's ability to handle higher velocities safely and effectively.
What are the psychological effects of experiencing high velocities?
Experiencing high velocities can have several psychological effects, including increased adrenaline and excitement. However, it can also lead to stress and anxiety for some individuals, especially if the high velocity is perceived as dangerous. The thrill of speed is often sought after in activities like roller coasters and racing, providing a sense of exhilaration and heightened sensory awareness.
