Velocity - conservation of momentum and kinetical energy
In summary, the speed of the projectile is 751 m/s and 3.37 kJ of energy is lost during the collision.
mstud
69
The speed of a projectile is measured by shooting it into a sanbox hanging in 6.00 m long threads. The projectile has a mass of 12.0 g, and the sandbox has a mass of 3.00 kg. The projectile ends up laying still in the sandbox. Thus the sandbox and the projectile moves as one body after the collision. The pendulum with the sandbox swings out and up after the shot until it reaches it's largest angle with the vertical line, 22.5 degrees.
a) Find the speed of the projectile before it hits the sandbox.
b) How much kinetical energy is lost during the collision?
Answers:
a) 751 m/s, b) 3.37 kJ.
Linear momentum: p=mv
Conservation of linear momentum: [itex]p_{before}=p_{after} \Leftrightarrow m \cdot v_0=(m+M)v[/itex]
where m is the mass of the projectile and M the mass of the sandbox, v_0 the initial velocity of the projectile and v the velocity of the projectile-sandbox body.
Conservation of mechanical energy: [itex]mgh=\frac 12 mv^2[/itex] where m is mass, g is 9.81 m/s^2, h is height and v is velocity.
a)
I tried to calculate the speed of projectile-sandbox just after the collision by using that it's swinging up with mechanical energy being conserved, but it seems I don't get the right answer (mechanical energy is conserved but kinetical energy is not, right?) :
I must use trigonometry to find the height the sandbox swings up.
Height from suspension to sandbox: [itex]\frac {x}{\sin 67.5}=\frac {6.00}{\sin 90} \Leftrightarrow x= 6.00 \cdot \sin 67.5 = 5.54 m[/itex]. This means the sandbox has swung 6.00 m - 5.54 m = 0.46 m upwards.
In this highest point the velocity of the body is 0, and its potential energy is [itex] mgh= (0.012 kg + 3.00 kg) \cdot 9.81 m/s^2 \cdot 0.46 m=13.6 J[/itex].
This means the body must have had an initial velocity of [itex]\frac 12 mv^2= 13.6 J \Leftrightarrow v=\sqrt{2\cdot 13.6}=5.215 m/s[/itex].
The initial velocity of the projectile is then:
[itex]m_{projectile} \cdot v_{projectile} = m_{body} \cdot v_{body} \Leftrightarrow v_{projectile}=\frac{m_{body} \cdot v_{body}}{m_{projectile}}
=\frac{(0.012 kg+3.00 kg)\cdot 5.215 m/s}{0.012 kg}=1.309 \cdot 10^3 m/s[/itex], which is not the correct answer.
Can anybody please help me get this right?
your method is perfectly correct but you have miscalculated the velocity of the box after the collision
you have 1/2(mv^2) = 13.6 J and I think you have forgotten to include 'm' in your calculation.
I got v = 3 m/s
Mistake here. You forgot to divide by the mass (which should actually be called (M+m) as per your nomenclature).
Much easier to manipulate this symbolically:
[itex]\frac{1}{2}(M+m)v^2 = (M+m)gh = (M+m)gL(1 - \cos\theta)[/itex] where [itex]\theta[/itex] is the angle subtended from the vertical, as given.
Then [itex]v = \sqrt{2gL(1 - \cos\theta)}[/itex] which is much less error-prone.
A word of advice: whenever doing multi-part mechanics (or even physics in general) problems, try to manipulate everything symbolically until the very last stage when you plug in the values. The benefit is that this process is less likely to cause errors like this, with you being able to keep track of what's going on (conceptually) at every stage; you're also able to reduce intermediate round-off errors. And in some problems, it's absolutely essential you learn how to do this as you need things to cancel out, otherwise you just can't solve the problem (quite typical of Olympiad type mechanics problems).
And please keep your variables consistent.
Thanks a lot for your correction and advice!
:smile:
First of all, it is important to note that the given answer of 751 m/s for the initial velocity of the projectile is incorrect. Based on the calculations provided, the correct answer should be 1.309 km/s or 1,309 m/s. This is a significant difference and could potentially lead to incorrect conclusions if not corrected.
Now, let's analyze the solution provided. The approach of using conservation of mechanical energy to find the initial velocity of the projectile-sandbox body is correct. However, there are some errors in the calculations.
First, the height of the sandbox swing should be calculated as follows:
Height from suspension to sandbox: \frac {x}{\sin 67.5}=\frac {6.00}{\sin 22.5} \Leftrightarrow x= 6.00 \cdot \sin 67.5 = 5.54 m. This means the sandbox has swung 6.00 m - 5.54 m = 0.46 m upwards.
The angle used should be 22.5 degrees, not 90 degrees, as the sandbox reaches its highest point when it makes an angle of 22.5 degrees with the vertical line.
Next, the potential energy calculation should be corrected to include the correct mass of the projectile. The potential energy at the highest point should be:
mgh= (0.012 kg) \cdot 9.81 m/s^2 \cdot 0.46 m= 0.053 J.
Finally, the calculation for the initial velocity of the projectile should be corrected as follows:
=\frac{(0.012 kg+3.00 kg)\cdot 5.215 m/s}{0.012 kg}= 5.215 m/s.
This is the correct initial velocity of the projectile, which can be converted to 5.215 m/s = 5.215 \cdot 1000 mm/s = 5,215 mm/s = 5.215 km/s. Therefore, the correct answer for the initial velocity of the projectile is 5.215 km/s or 5,215 m/s.
To answer part b) of the question, we can use the conservation of mechanical energy again. The initial mechanical energy of the projectile-sandbox body is:
E_{initial} = \frac 12
Related to Velocity - conservation of momentum and kinetical energy
1. What is the definition of velocity?
Velocity is the rate of change of an object's position with respect to time. It is a vector quantity that includes both magnitude (speed) and direction.
2. How is velocity related to conservation of momentum?
In a closed system, momentum is conserved, meaning that the total momentum before a collision is equal to the total momentum after the collision. This includes both the momentum of the objects involved as well as their combined velocity.
3. What is the role of kinetic energy in velocity?
Kinetic energy is the energy an object possesses due to its motion. It is directly related to velocity, as an object with a higher velocity will have a greater kinetic energy.
4. Can velocity be negative?
Yes, velocity can be negative. This indicates that the object is moving in the opposite direction of the chosen coordinate system. For example, a car traveling westward would have a negative velocity if the positive direction is defined as eastward.
5. How does velocity affect an object's acceleration?
Acceleration is directly related to velocity, as it is the rate of change of an object's velocity with respect to time. An increase in velocity will result in a greater acceleration, and a decrease in velocity will result in a smaller acceleration.
9K
