Velocity correlations and molecular chaos
In summary: Well, even if you do manage to put exactly the same force on each particle, there will be other forces (collisions) which are unpredictable, destroying perfect correlation.
"Don't panic!"
601
I’ve been reading up about Boltzmann transport equations, and the concept of molecular chaos has come up, in which one assumes the velocities of particles are assumed to be uncorrelated. I’m a bit confused about the concept though. In what sense do the velocities become correlated in the first place?
Does it mean that, when the particles collide with one another, their outgoing velocities become related to one another, since they exchange kinetic energy, and thus correlated?
Wind is an example of correlated motion.
By that do you mean that the velocities of air molecules at neighbouring points will be similar (in magnitude and direction), and hence are correlated?
Yes.
With typical wind speeds the correlation is small (a few m/s over several hundred m/s random motion), but they are correlated. If one molecules moves to the left all the surrounding molecules are also a bit more likely to move to the left.
mfb said:
Yes.
Ah ok. So, in the abstract case of a gas of particles, do their velocities become correlated via collisions with one another (due to transfer of momentum)?
That can happen, but it doesn't happen if your gas is at rest, has no external forces and so on.
What if it is out of equilibrium and thermalising?
Also, am I correct in saying that the correlations in the velocities are due to collisions between particles, and momentum conservation relating their velocities?
Then it depends on your initial conditions.
I don't think that is a useful description.
How should one understand it then? How do velocities become correlated?
If the velocities are correlated, then the average velocity will be non-zero. That means the gas as a whole is going somewhere. If you want to make the velocities correlated, you can put a hole in the container, allowing the gas to stream out (into vacuum or lower pressure), and in the region of stream, the velocities are correlated, which means that if the velocity of one molecule is pointing out through the hole, there is a high probability that the velocity of another moloecule iss also pointing out of the hole, streaming along with the first one.
Generally, collisions between particles tend to restore equilibrium, making the velocities uncorrelated. The correlation which I described above is because of an external force (pressure difference).
Is this because they are all being acted upon by the same external force, causing a net motion in a particular direction, such that the velocities of neighbouring are likely to be similar, i.e. there is a statistical relation between their velocities as a result of them being acted upon by an external force (pointing in a particular direction)?
This is not an external force which you directly apply to each molecule, but is an average force transmitted through the gas, but with that understanding, I believe you are correct.
If this were the case then the velocities of each molecule would be perfectly correlated (at least in the sense that they will all be pointing in the same direction), right?
Is it correct to say that because it is an average force, not all the particle velocities will be pointing in the same direction, however, neighbouring velocities will be correlated, such that if one particle has a given velocity, then the neighbouring particles will have velocities similar to it?
Well, even if you do manage to put exactly the same force on each particle, there will be other forces (collisions) which are unpredictable, destroying perfect correlation. It is only if the particles are not interacting with each other that you can have perfect correlation. But your second statement sounds right.
By this do you mean that if an external force is acting on each particle, but there is no inter-particle interactions, then there will be a perfect correlation?
Why would correlations be present for a gas of particles out of thermal equilibrium? When deriving a Boltzmann equation, one assumes molecular chaos when determining the collision integral, i.e. neglects correlations between particle velocities. How do these correlations arise though, if collisions tend to destroy correlations?
Part 1. Yes. If these are non-interacting particles, and if there is a known force acting on each of them, the problem boils down to the motion of a single particle under a known force, the future is completely predicted for each particle, and there is complete correlation among the velocities.
Part 2. We already discussed a case of streaming in which the velocities are correlated. You can start the streaming, let the correlations develop, and then stop the streaming by putting a stopper against the stream, and then wait for thermal equilibrium to develop, and that last step happens by interparticle collisions, which destroy the velocity correlations.
Is this because the collisions cause particles to scatter, resulting in neighbouring particle velocities becoming more and more randomly directed?
That seems to be a reasonable picture
Okay, great. Thanks for your time and help!
Related to Velocity correlations and molecular chaos
1. What is the concept of velocity correlations in molecular chaos?
Velocity correlations refer to the relationship between the velocities of different molecules in a gas. In molecular chaos, the velocities of individual molecules are considered to be completely random and uncorrelated with each other.
2. How are velocity correlations and molecular chaos related to each other?
In molecular chaos, the velocities of individual molecules are assumed to be uncorrelated, meaning that there is no relationship or pattern between them. This allows scientists to make predictions about the overall behavior of a gas based on statistical averages rather than tracking the movement of each individual molecule.
3. What is the significance of velocity correlations and molecular chaos in the study of gases?
Understanding velocity correlations and molecular chaos is crucial in the study of gases because it allows scientists to make accurate predictions about the behavior of gases on a macroscopic level. This is important in various fields such as thermodynamics, fluid mechanics, and atmospheric science.
4. Can velocity correlations and molecular chaos be observed in real-world situations?
While it is difficult to directly observe the velocities of individual gas molecules, the predictions made by molecular chaos have been validated by numerous experiments and observations. This supports the idea that velocity correlations and molecular chaos accurately describe the behavior of gases in real-world situations.
5. How do velocity correlations and molecular chaos relate to the kinetic theory of gases?
The kinetic theory of gases is based on the assumptions of molecular chaos and velocity correlations. It states that gases consist of a large number of molecules in constant random motion, and that the pressure and temperature of a gas are directly related to the average kinetic energy of its molecules. Therefore, an understanding of velocity correlations and molecular chaos is essential in the application of the kinetic theory of gases.
14K
