Velocity emparted to a mass by the decompression of a spring
In summary, the conversation discusses the calculation of the velocity of a 3 kilogram mass when pushed by a 1.5 inch spring with a spring force of 400 lbs per inch. The given equation V=(2F*t2)/3.14M does not seem to make intuitive sense due to the T2 term. The suggestion is made to approach the problem using conservation of energy and ignoring the time.
NTL01
A 1.5 inch spring is .75 inches at solid length when fully compressed. The spring force is rated at 400 lbs per inch. A 3 kilogram mass will be pushed by the spring. What is the velocity of the mass at the instant the spring has fully decompressed. It will take the spring 1/20 of a second to decompress
2. Relevant equation
An equation was offered to me by a tutor as follows
V=(2F*t2)/3.14M
Where F is the force of the spring in Newtons, T2 is the time it takes for the spring to decompress , M is the mass being pushed
I don't have any trouble solving this equation because I have all the variables. What troubles me is I don't think it makes intuitive sense because of the T2 term. The slower the spring decompresses the more the velocity goes up, which just doesn't seem logical
I am seeking comments , and possibly an alternative formula.
The formula above was derived by use of hooks law and the F=MA resolved into a differential equation, and I can't follow the derivation well enough to see if there was a mistake
I don't recognize the given formula, and as you say it doesn't appear to behave properly. I'm thinking that it may be an effort to use a mass-spring oscillator analysis to determine a velocity at a specific time in the cycle. Otherwise I can't see why there appears to be a pi value in it.
I would suggest that you approach this using conservation of energy and ignore the time.
Related to Velocity emparted to a mass by the decompression of a spring
1. What is velocity imparted to a mass by the decompression of a spring?
Velocity imparted to a mass by the decompression of a spring refers to the speed at which the mass moves after being released from a compressed spring. It is a result of potential energy being converted into kinetic energy as the spring decompresses.
2. How is velocity imparted to a mass by the decompression of a spring calculated?
The velocity imparted to a mass by the decompression of a spring can be calculated using the equation v = √(2k/m), where v is velocity, k is the spring constant, and m is the mass of the object.
3. What factors affect the velocity imparted to a mass by the decompression of a spring?
The velocity imparted to a mass by the decompression of a spring is affected by the spring constant, the mass of the object, and the initial compression of the spring. A stiffer spring, lighter mass, and greater compression will result in a higher velocity.
4. Is the velocity imparted to a mass by the decompression of a spring constant?
No, the velocity imparted to a mass by the decompression of a spring is not constant. It is dependent on the factors mentioned above and will change with different conditions.
5. Can the velocity imparted to a mass by the decompression of a spring be used to determine the spring constant?
Yes, the velocity imparted to a mass by the decompression of a spring can be used to determine the spring constant using the rearranged equation k = m(v^2/2), where k is the spring constant, m is the mass of the object, and v is the velocity. The value of the spring constant will remain constant for a specific spring, regardless of the mass or initial compression used.
