Velocity in relation to Electric charges.
In summary: For part (c), you can use conservation of momentum to find the final velocity of particle m1. For part (d), you can use conservation of energy to find the final velocity of particle m2.In summary, you are trying to find the speed at the instant of closest approach, the distance of closest approach, and the velocities of the two particles after the interaction. This involves using the equations for force, acceleration, conservation of energy, and conservation of momentum. By simplifying the equation for velocity at the center of mass, you can find the speed at the instant of closest approach. Using conservation of energy, you can find the distance of closest approach. And for the final velocities of the particles, you can use conservation of momentum
ejezisek
From a large distance away, a particle of mass m1 and positive charge q1 is fired at speed v in the positive x direction straight toward a second particle, originally stationary but free to move, with mass m2 and positive charge q2. Both particles are constrained to move only along the x axis. (Use any variable or symbol stated above along with the following as necessary: ke for 1
4πε0
(a) At the instant of closest approach, both particles will be moving at the same speed. Find this speed.
(b) Find the distance of closest approach.
After the interaction, the particles will move far apart again. At this time, find the velocity of the following.
(c) the particle of mass m1
(d) the particle of mass m2
F=ma
F=q1*q2/r^2
There are probably more but, I'm not entirely sure what they are.
For part a. I got the correct answer v-(v/(m1*(1/m1+1/m2))
For part b I tried to use the antiderivative of Part a. I also tried extracting r^2 from the formulae in part a. ie. vi-Δv1=Δv2
However I made a few errors in this part and do not know how to calculate Δv1. I am not entirely sure why part a is correct because I, instead of plugging in values for Δv I used values for acceleration.
For part C I tried using the acceleration formula I used in Part A. F/m=a and I've been trying to figure out the Δv. However I forgot/never knew how to do it.
I have not yet started part D. However I figure it to be about the same as part c.
Thank you for your help.
Some updates I've made regarding the work to part 3. Due to conservation of energy, the velocity of particle 1 - change in velocity = velocity of particle 2 + change in velocity of particle 1 * m2/m1
4πε0
F=ma
F=q1*q2/r^2
For superscripts & subscripts: Use the X2 and X2 buttons in the toolbar in the second line at the top of the message box. (as you type in your message.)
It might be helpful to use the idea of "center of mass". You already found the velocity, Vcm, of the center of mass: Vcm = v·(m1/(m1+m2)) which is the result of simplifying v‒(v/(m1·(1/m1+1/m2)).
For (b): Use conservation of energy to find the distance of closest approach. What's the potential energy of the system when the two particles are separated by distance r ?
For parts (c) & (d): It's an elastic collision. KEinitial = KEfinal .
Related to Velocity in relation to Electric charges.
1. What is velocity in relation to electric charges?
Velocity in relation to electric charges refers to the speed at which charged particles move in an electric field. It is a measure of how quickly a charged particle is moving in a particular direction.
2. How is velocity related to electric charges?
Velocity is directly related to electric charges. As the magnitude of the electric charge increases, the velocity of the charged particle also increases. Additionally, the direction of the electric field can also affect the velocity of the charged particle.
3. What is the formula for calculating velocity in relation to electric charges?
The formula for calculating velocity in relation to electric charges is v = E/q, where v is the velocity, E is the electric field strength, and q is the electric charge of the particle.
4. How does velocity affect the behavior of electric charges?
The velocity of electric charges affects their behavior in several ways. First, it determines the strength of the electric current produced by the charges. Additionally, the velocity of charged particles can also affect the strength and direction of the magnetic field they produce.
5. Can velocity of electric charges be changed?
Yes, the velocity of electric charges can be changed by altering the electric field or by applying external forces. For example, the velocity of electrons in a wire can be increased by increasing the electric field strength or by exposing the wire to a magnetic field.
