Velocity of a Cart accelerated by a Jet stream
In summary: M", then you could set M = 0 and solve for V.This can be accounted for by having an initial condition that allows for the initial volume of the fluid to have the same mass of the cart.
Will1119
Thread moved from the technical forums, so no Homework Help Template is shown
This is a problem for a fluid dynamics class I'm in. My current approach is to use a conservation of mass approach and say that the d/dt(momentum in the cart) = momentum into the cart. This leads to (u is speed of the cart, V is volume J is jet velocity, A is cross sectional area of the jet)
d/dt(Vρu) = ρ dV/dt J
where the left hand term represents the derivative of the current momentum of the cart, and the right hand term represents to momentum flux into the cart.
I found that the rate at which water from the jet enters the cart will be
dV/dt = A (J-u), i.e. the faster the cart is going the less water that actually enters it. Going back, and cancelling density,
d/dt(Vu) = dV/dt J
V' u + u' V = V' J, where prime is a time derivative.
u' = V'(J-u)/V
a = u' = A (J-u)^2/V
but I can't proceed from here. Not only is the differential equation nonlinear, but the volume in the denominator will be an integral depending on u,
V(t) = Vo + ∫(0 to t) V'(τ)dτ = Vo + A J t - A∫(0 to t) u(τ)dτ
Since I couldn't solve it analytically I used numerical integration to get the u vs t curve and it looks as you'd suspect, with asymptotic behavior near u=J
My question is whether or not there is a symbolic answer, and if so how is it obtained?
Hi Will. Thanks for your interest. Here is I found out, shortly after joining this site. The questioners are expected to pose what they know about the problem, and any attempts at a solution. Then people will offer guidance to help the asker along and gain further understanding.
Do you understand what laws would be applicable to this type of problem? I noticed that you tagged it with momentum. What can you say about the momentum of the cart? Momentum of the water?
Since there are not any numbers, you will have an answer as an expression with a bunch of variables. What assumptions will you need to make? I hope this helps you get started.
Likes Will1119
I'm new here, updated the post
Is there any reason you decided to rely solely on conservation of mass for a problem involving forces and acceleration?
I like everything you did. So now you have two coupled differential equations
V' = Ak
k' = -A k2/V
And you know the initial conditions: V0 = 0 and k0 =J
What do you get when you integrate V'?
I used a conservation of mass approach (we are covering the momentum tensor in my continuum mechanics class right now and I am quite sure this is the approach eh wanted us to use). The conservation of mass only plays a role since the mass of the cart varies with time.
V' = Ak
k' = -A k2/V
this is exactly where I am stuck. If i try to integrate V the expression involves an integral of k,
V(t) = Vo + A ∫(0 to t) k dτ
but I don't see how that helps. I did try doing something along the lines of
V'' = A k'
k' =V''/A ,
k' = -A k2 /V
V''/A = -A k2 /V
V'' = -A2k2/V
V * V'' = V'2
but this is nonlinear and not easy to solve.
I threw your coupled diff eqs into wolfram alpha and they game me fairly simple analytic solutions though. using the same IC's I used when i numerically integrated it also gave me the same results. I am just unsure how to solve these Diff Eqs
Shouldn't you allow for the fact that the empty cart has some mass?
i.e. if it said "the initial mass of the cart and water at time 0 is 100 lbs..." you could set Vo = 100lbs/(density of water). We treat the IC as cart of mass 0 and initial water of mass 100 lbs, which has the same effect.
Likes scottdave
OK. Sounds good.
Note that you can integrate d/dt(Vu) = dV/dt J immediately. ("Cancel" the dt on each side.)
Use the result to help solve dV/dt = A (J-u).
TSny said:
OK. Sounds good.
Yes I think that could be the key, right there.
Related to Velocity of a Cart accelerated by a Jet stream
1. What is the velocity of a cart accelerated by a jet stream?
The velocity of a cart accelerated by a jet stream depends on the speed and direction of the jet stream, as well as the initial velocity of the cart. It can be calculated using the principles of vector addition.
2. How does a jet stream affect the velocity of a cart?
A jet stream can either increase or decrease the velocity of a cart depending on its direction and speed. If the jet stream is in the same direction as the cart's initial velocity, it will increase the velocity. If it is in the opposite direction, it will decrease the velocity.
3. Can a cart be accelerated by a jet stream in any direction?
Yes, a cart can be accelerated by a jet stream in any direction as long as the jet stream has a non-zero velocity. However, the direction and speed of the jet stream will determine the magnitude and direction of the cart's acceleration.
4. How can the velocity of a cart accelerated by a jet stream be measured?
The velocity of a cart accelerated by a jet stream can be measured using a velocity measuring device, such as a radar gun or a speedometer. The velocity can also be calculated using the distance traveled and the time taken.
5. What factors can affect the velocity of a cart accelerated by a jet stream?
The velocity of a cart accelerated by a jet stream can be affected by the speed and direction of the jet stream, the initial velocity of the cart, and any external forces acting on the cart, such as friction or air resistance. The mass and shape of the cart can also play a role in its velocity.
