Velocity of a freely falling object
In summary, the conversation discusses finding the velocity and total distance traveled of a freely falling object, as well as whether velocity is affected by mass and aerodynamic considerations. The formula for velocity is used to calculate the velocity of the object, and the distance formula is used to find the total distance traveled. It is noted that acceleration due to gravity is constant for all objects, but aerodynamic considerations can affect the velocity of an object.
ashleyFGCU
A certain freely falling object, released from rest, requires 1.65 s to travel the last 39.0 m before it hits the ground.
(a) Find the velocity of the object when it is 39.0 m above the ground. (Indicate the direction with the sign of your answer. Let the positive direction be upward.)
(b) Find the total distance the object travels during the fall.
v=v°+at
a=v-v°/t
distance Δx=vavg(t)
a) To find the velocity I am simply using the velocity formula, and making a=-9.8 because it is falling down.
v=0+1.65s(-9.8)=-16.17m
When I put -16.17 into the answer online it response is within 10% of the correct value. This may be due to roundoff error, or you could have a mistake in your calculation. Carry out all intermediate results to at least four-digit accuracy to minimize roundoff error.
I also tried -16.2, but before I use another try (I only have 3 left) I wanted to make sure that I am close to the answer, so I can try rounding to 16m/s.
b) I am confused on this one but I got 47.1m and it tells me the same thing, that I am within 10% of the correct value.
You have distance (-39.5 meters), you have time (1.65 seconds) and you have acceleration (-9.8 meters/s2). You should know the formula s = v0t + at2/2. So you should be able to find v0 from this equation. That's part 1.
For part 2, you have v0 that the object acquired after falling for some unknown time. For this, you should be able to find out the time. Then use the distance formula again to find out the total distance.
Does velocity of freely falling object depends on mass?
No. Acceleration due to gravity is a constant g=9.807 m/s^2 for all objects regardless of mass. Only aerodynamic considerations will affect the velocities.
wreckemtech said:
No. Acceleration df2f
what do mean by aerodynamic consoderations?! consider a book and a large car dropped from a certain height. car reaches first and That is due to the surface area of the car more then book and so atmosphEric pressure acting on the car is more , so car reaches ground first. Am I right? But the velocity that the both the bodies hit the ground is same.
A larger surface area in relation to the mass of an object is likely to slow it. Think "wind resistance" slowing the acceleration of an object. In a vacuum, a feather and a bowling ball dropped from any height will hit the ground at the same time. Whereas in actual atmospheric conditions, the feather will fall much more slowly than the bowling ball because the feather has a huge surface area in relation to its mass.
FAQ: Velocity of a freely falling object
What is the velocity of a freely falling object?
The velocity of a freely falling object is the speed at which it is moving downward towards the ground due to the force of gravity.
What factors affect the velocity of a freely falling object?
The velocity of a freely falling object is affected by the acceleration due to gravity, the mass of the object, and the air resistance or drag acting on the object.
How is the velocity of a freely falling object calculated?
The velocity of a freely falling object can be calculated using the formula v = gt, where v is the velocity, g is the acceleration due to gravity, and t is the time elapsed.
Does the velocity of a freely falling object change during its fall?
Yes, the velocity of a freely falling object changes continuously during its fall as it accelerates due to the force of gravity.
What is the relationship between velocity and time for a freely falling object?
The relationship between velocity and time for a freely falling object is directly proportional, meaning that as time increases, the velocity of the object also increases at a constant rate.
