Velocity of a particle when acceleration based on displacement
In summary, the conversation discussed a homework problem involving the chain rule and integration. The problem asked for the velocity of a particle, which can be found using vector equations for each component. One person was able to find the magnitude of the velocity but not the direction, and asked for help in finding it.
ivanallen
[PLAIN]http://img690.imageshack.us/img690/5817/problem001.jpg
Chain rule : dv/dt=dv/dr*dr/dt
Integration
I can only find the speed (the magnitude of the velocity), that is
[PLAIN]http://img268.imageshack.us/img268/4996/95620213.jpg
I have no idea how to consider its direction. :frown:
Does it involve vector integration or higher mathematic knowledge?
Help me, please, I'm dying to know the answer, thank you. :!)
Where is the problem?
Problem is I can't find the direction of the velocity of this paricle, the only thing I can find is its magnitude.
In the question above, it asks for the velocity, so only magnitude is not enough.
Please show me how to find its direction. Thanks.
You have a vector equation, one equation for each component, x, y, z. ehild
First of all, great job on using the chain rule to find the velocity! You are correct that the magnitude of the velocity can be found by taking the derivative of the displacement with respect to time. However, in order to find the direction of the velocity, we need to take into account the direction of the displacement and the acceleration.
To do this, we can use vector calculus. The velocity can be written as a vector, with components in the x, y, and z directions. We can then use the chain rule to find the components of the velocity vector:
vx = (dx/dt)(dt/dr) = dx/dr * (dr/dt)^-1
vy = (dy/dt)(dt/dr) = dy/dr * (dr/dt)^-1
vz = (dz/dt)(dt/dr) = dz/dr * (dr/dt)^-1
So, in order to find the direction of the velocity, we need to know the direction of the displacement (dx/dr, dy/dr, dz/dr) and the direction of the acceleration (d^2x/dr^2, d^2y/dr^2, d^2z/dr^2). These can be found by taking the second derivative of the displacement with respect to time. Once we have these values, we can use vector addition to find the direction of the velocity.
To summarize, in order to find the velocity of a particle when acceleration is based on displacement, we need to use the chain rule to find the magnitude of the velocity and vector calculus to find the direction of the velocity. This may involve higher level mathematical concepts, but it is important to understand these concepts in order to fully understand the motion of particles in space. Keep up the good work!
FAQ: Velocity of a particle when acceleration based on displacement
What is the definition of velocity?
Velocity is a measure of the rate of change of an object's position over time. It is a vector quantity and includes both magnitude (speed) and direction.
How is velocity related to acceleration and displacement?
Velocity is directly related to acceleration and displacement. Acceleration is the rate of change of velocity, and displacement is the change in an object's position. Therefore, if acceleration is known, velocity can be calculated by integrating the acceleration with respect to time. Similarly, if the displacement is known, velocity can be calculated by taking the derivative of the displacement with respect to time.
What is the formula for calculating velocity?
The formula for calculating velocity is v = Δx/Δt, where v is velocity, Δx is displacement, and Δt is time. This formula is based on the average velocity, and for more accurate results, the instantaneous velocity can be calculated by taking the derivative of the displacement function with respect to time.
How does acceleration affect the velocity of a particle?
Acceleration affects the velocity of a particle by changing its speed and/or direction. If the acceleration is in the same direction as the velocity, the particle's speed will increase. If the acceleration is in the opposite direction, the particle's speed will decrease. Additionally, if the acceleration is perpendicular to the velocity, it will cause a change in direction without affecting the speed.
Can the velocity of a particle be negative?
Yes, the velocity of a particle can be negative. This indicates that the particle is moving in the opposite direction of the chosen reference frame. For example, if a car is moving towards the east with a velocity of 20 m/s, its velocity can be represented as -20 m/s if the chosen reference frame is towards the west.
