Velocity of a planet around the sun
In summary, the conversation discusses the motion of a planet in an elliptical orbit around the sun and the relationship between its perihelion and aphelion distances and speeds. The resulting equation, va = rpvp/ra, is verified using conservation of momentum and energy, as well as Kepler's law.
hs764
1. Asking because the answer I got seems too simple...a planet of mass m moves in an elliptical orbit about the sun. The minimum and maximum distances of the planet from the sun are called the perihelion and aphelion respectively. If the speed of the planet at p is vp, what is its speed at a? Assume the distances rp and ra are known.
dA/dt = 1/2r2ω, ω=v/r[/B]
dA/dt is constant, so 1/2rp2ωp = 1/2ra2ωa. Substitute v = ωr, that gives 1/2rpvp = 1/2rava, va = rpvp/ra. Is this correct?[/B]
Try verifying the result from another rule - like conservation of momentum and energy...
So using conservation of momentum I got the same thing...dA/dt = L/2m = mr2ω/2m. Given that ω = v/r, rpvp/2 = rava/2, va = rpvp/ra.
Yes, it is the same thing as Kepler's law. Good job.
Great, thank you!
Related to Velocity of a planet around the sun
1. What is the velocity of a planet around the sun?
The velocity of a planet around the sun is the speed at which the planet moves in its orbit around the sun. It is determined by the mass of the planet, the mass of the sun, and the distance between them.
2. How is the velocity of a planet around the sun calculated?
The velocity of a planet around the sun can be calculated using Newton's law of universal gravitation, which states that the force of gravity between two objects is directly proportional to their masses and inversely proportional to the square of the distance between them. This equation can be rearranged to solve for the velocity of the planet.
3. Does the velocity of a planet around the sun change?
Yes, the velocity of a planet around the sun can change due to factors such as the planet's position in its orbit, the influence of other planets, and the effects of gravity from other objects in the solar system.
4. What is the relationship between the velocity of a planet around the sun and its orbital period?
The velocity of a planet around the sun is directly related to its orbital period, which is the time it takes for the planet to complete one full orbit around the sun. This means that as the velocity increases, the orbital period decreases, and vice versa.
5. How does the velocity of a planet around the sun affect its temperature?
The velocity of a planet around the sun does not directly affect its temperature. However, the distance of the planet from the sun and the amount of solar radiation it receives can impact its temperature. A planet with a higher velocity may be closer to the sun and receive more solar energy, resulting in a higher temperature.
