Jake 7174
- 80
- 3
If a charge of +2 µC and mass 2 g is taken to (0,0,4) in the presence of an electric field due to a ring {R : x2 + y2 = 25,z = 0} of uniform charge density ρL = +3µ C/m, and then released, find the maximum velocity it gains.
Given in the problem:
You solve the equation 1/2 mv^2 = W for v
W = -q * ∫E ⋅dl
E = q / (4πε0r^2)
We are given 1/2 mv^2 = W (which I thought was for kinetic energy not work) and told to solve.
First I find E from the ring using variables
dq = λ r dΦ (cylindrical coordinates gives the r)
unit vector = <-r ar, z az> / sqrt (r^2 + z^2) - ar cancels
E = ∫ λ z r dΦ / [4πε0 (r^2 + z^2)^(3/2)] from Φ=0 to 2π = λ r z / [(2ε0 (r^2 + z^2)^(3/2)]
I am confused about finding work from this I have the equation W = -q * ∫E ⋅dl. I assume the q here is the point charge and dl is dz so my equation is
-q ∫ λ r z dz / [(2ε0 (r^2 + z^2)^(3/2)] I am unsure if this is correct or what my limits should be My guess is from 0 to 4.
Also, if there is a better approach I am all ears. The problem does not require me to use any specific method. Also, this is a test review with the solution given. I already know the answer.
