Velocity of flow in cylindrical coordinates
In summary, the velocity of the flow in the cylindrical coordinates is given by \vec u = \left\langle 0,{u_\theta }(r,t),0 \right\rangle, and thus {{u_r}(r,t)} = 0.
glebovg
164
An infinitely long cylindrical bucket with radius [itex]a[/itex] is full of water and rotates with constant angular velocity [itex]\Omega[/itex] about its horizontal axis. The gravity is in the vertical direction. The velocity of the flow in cylindrical coordinates (whose [itex]z[/itex] axis is the horizontal axis of the bucket) is given by [itex]\vec u = \left\langle {{u_r}(r,t),{u_\theta }(r,t),0} \right\rangle[/itex].
Show that [itex]{{u_r}(r,t)} = 0[/itex].
I actually have no idea how to start. Any help will be appreciated.
Since the bucket is rotating with a constant angular velocity \Omega, the Coriolis force is zero. Therefore, the only forces acting on the flow are gravity and the centrifugal force. The centrifugal force is perpendicular to the radial direction, and so it cannot affect the radial component of the velocity. The gravity also cannot affect the radial component as it is in the vertical direction. Therefore, the only force acting on the radial component of the velocity is zero, and hence the radial component must be zero.
FAQ: Velocity of flow in cylindrical coordinates
1. What is the formula for calculating velocity of flow in cylindrical coordinates?
The formula for calculating velocity of flow in cylindrical coordinates is v = (u*cos(theta))i + (u*sin(theta))j + w*k, where u is the velocity component in the radial direction, theta is the angle measured from the z-axis, and w is the velocity component in the z-direction.
2. How does the velocity of flow change with respect to the radius in cylindrical coordinates?
In cylindrical coordinates, the velocity of flow is directly proportional to the radius, meaning that as the radius increases, the velocity also increases. This can be seen in the formula v = (u*cos(theta))i + (u*sin(theta))j + w*k, where u is dependent on the radius.
3. What is the significance of the velocity of flow in cylindrical coordinates?
The velocity of flow in cylindrical coordinates is important in understanding the movement of fluids in cylindrical systems. It helps to determine the rate at which fluids flow and how they behave in different parts of the system.
4. How does the angle theta affect the velocity of flow in cylindrical coordinates?
The angle theta plays a crucial role in determining the direction of the velocity of flow in cylindrical coordinates. As theta increases, the velocity shifts towards the tangential direction, while a decrease in theta results in a shift towards the radial direction.
5. Can the velocity of flow in cylindrical coordinates be negative?
Yes, the velocity of flow in cylindrical coordinates can be negative. This indicates that the fluid is flowing in the opposite direction of the positive direction defined by the coordinate system. Negative velocities can occur in regions of recirculating flows or when there is a change in direction of the fluid flow.
