Velocity of Klein-Gordon particles of mass m
That's why in QM a particle is described by a wave packet, which is a superposition of plane waves, where each plane wave has a slightly different momentum.
ProPatto16
326
Show that [tex]ψ(x,t)=Ae^{i(kt-ωt)}[/tex] is a solution to the Klein-Gordon equation [tex]\frac{∂
^2ψ(x,t)}{∂x^2}-\frac{1}{c^2}\frac{∂^2ψ(x,t)}{∂t^2}-\frac{m^2c^2}{\hbar^2}ψ(x,t)=0[/tex] if [tex]ω=\sqrt{k^2c^2+(m^2c^4/\hbar^2)}[/tex] Determine the group velocity of a wave packet made up of waves satisfying the Klein-Gordon equation. Show that [itex]E=\sqrt{p^2c^2+m^2c^4}[/itex] for these particles and show that speed v is equal to the group velocity.
The last proof, show that the speed = group velocity, is where I'm having trouble. I've done the rest. The solution I got for group velocity is
[tex]V_g=\frac{∂ω}{∂k}=\frac{kc^2}{\sqrt{k^2c^2+(m^2c^4/\hbar^2)}},[/tex] so now the way I've been trying to solve this is taking the expression for E and manipulating it trying to achieve Vg.
Using equations like [itex]E=\hbar\omega,E=\frac{p^2}{2m},p=mv,E=\frac{mv^2}{2},p=\hbar k[/itex] among others, I can't get it to equate.
I can get down to [itex]V_g=\sqrt{c^2+v^2}[/itex] but that's the closest I've got.
Just a subtle hint at a starting point would be great. Thanks.
You need to use relativistic formulas. In particular, the velocity of a particle is given by p/E.
Using v=p/E i can solve it only if vph= v
From what i understand the phase velocity is the velocity of a particular point on a single wave of the packet. that's analogous to speed of the particle yes? so v is indeed equal to vph
I'm not following your reasoning. Can you elaborate a bit more?
[tex]V_g=\frac{kc^2}{\sqrt{k^2c^2+m^2c^4/\hbar^2}}[/tex]
[tex]V_{ph}=\frac{p}{E}=\frac{p}{\sqrt{p^2c^2+m^2c^4}}[/tex]
[tex]p=\hbar k[/tex]
[tex]=\frac{\hbar k}{\sqrt{\hbar^2k^2c^2+m^2c^4}}[/tex]
[tex]=\frac{k}{\sqrt{k^2c^2+(m^2c^4)/\hbar^2}}[/tex]
[tex]V_{ph} V_g = c^2 ∴ V_{ph}=c^2/V_g[/tex]
but i need [tex]V_{ph}=V_g/c^2[/tex]...
You're not going to get that because your expression for the group velocity is
$$V_g = \frac{kc^2}{\sqrt{k^2c^2+m^2c^4/\hbar^2}} = \frac{kc^2}{\omega} = \frac{c^2}{\omega/k} = \frac{c^2}{V_\text{ph}}$$
exactly.
So then how do i show that speed v = Vg if not by direct substitution.
i don't suppose it would be enough to sub in c=w/k
solves it in like 2 lines, end up with w/k=v
but that assumes v=c which isn't the case for particles with mass m...
I'm not sure why you took ##p/E## to be the phase velocity. It's the group velocity. (If you include the factors of c, it's actually ##\frac{V_g}{c} = \frac{pc}{E}##.)
okay now I am not following.
in your first post you said the velocity of a particle is given by p/E
i know that v=Vg but how do i show that.
if i take Vg=p/E and sub in E and play around i get nowhere.
how do i reduce p/E down to v..
It's an established result from relativity. Try dividing ##p=\gamma mv## by ##E=\gamma mc^2##.
thats works. i knew i needed a formula from outside of the ones i used to derive it all cause it goes back to just crap. but the v/c^2 gives me the missing c^2 I've needed.
Thanks a lot! bit of a dicky proof
In fact, if you assume that the phase velocity is the velocity of the particle you will see that the particle travels faster than the speed of light! On the other hand, the group velocity is always smaller than c. So if relativity is right, physical states must be a superposition of plane waves. However, you'll have an uncertainty in the position of the particle as well on the momentum.
Related to Velocity of Klein-Gordon particles of mass m
1. What is the formula for the velocity of Klein-Gordon particles of mass m?
The velocity of Klein-Gordon particles of mass m can be calculated using the formula v = p/E, where v is the velocity, p is the momentum, and E is the energy.
2. How does the velocity of Klein-Gordon particles compare to the speed of light?
The velocity of Klein-Gordon particles can reach the speed of light, but it is not limited to it. This means that it can be greater than or equal to the speed of light, but never slower.
3. Can the velocity of Klein-Gordon particles be negative?
Yes, the velocity of Klein-Gordon particles can be negative. This is because the Klein-Gordon equation allows for both positive and negative energy solutions.
4. What factors affect the velocity of Klein-Gordon particles?
The velocity of Klein-Gordon particles can be affected by various factors, such as the mass and energy of the particle, as well as external forces acting on it.
5. Is there a maximum velocity for Klein-Gordon particles?
No, there is no maximum velocity for Klein-Gordon particles. As mentioned earlier, the velocity can reach the speed of light, but it can also exceed it. However, the energy required for a particle to exceed the speed of light is infinite, making it physically impossible.
