Velocity of rain in different reference frames
In summary, The problem involves a car traveling east and rain falling vertically. The angle of the rain on the side windows of the car is given. The question asks for the velocity of the rain in both the reference frame of the car and the Earth. Using vector relationships and geometry, the velocities can be calculated.
dink87522
I'm having some trouble with the below vector question. I've got an answer although I'm not sure if it is correct or not.
A car travels due east with a speed of 40 kph. Rain drops are falling at a constant speed vertically with respect to Earth. The traces of the rain on the side windows of the car make an angle of 50 degrees with the vertical. Find the velocity of the rain in the following reference frames: a) the car b) the Earth
x = VxCosTheta
Y = VySinTheta
Trig
X = (40)/(3.6 * tan 50) = 17
Y = (40)/(3.6 * sin 50) = 14.5
Would it be a) 17 m/s b) 14.5m/s ?
Just look at the vector relationships between two reference frames.
Let [tex]\vec{v}[/tex] be velocity of the rain in the reference frame of the Earth, [tex]\vec{v'}[/tex] velocity of the rain in the reference frame of the car and [tex]\vec{V}[/tex] be velocity of the car.
Then we have this (pretty much obvious) relation,
[tex]\vec{v}=\vec{V}+\vec{v'} \Rightarrow \vec{v'}=\vec{v}-\vec{V}[/tex].
Now, if you draw vector diagram, you can clearly see direction of the rain in both references. Let [tex]\alpha[/tex] be the given angle. Then, from geometry of the problem, we get
[tex]\tan{\alpha}=\frac{v}{V} \Rightarrow v=V \tan{\alpha}[/tex].
From there you can get [tex]v'[/tex] using Pythagorean theorem.
Related to Velocity of rain in different reference frames
1. What is the velocity of rain in different reference frames?
The velocity of rain can vary depending on the reference frame, which is the point of view from which an observer is measuring the rain's velocity. In general, the velocity of rain is affected by factors such as wind speed, air resistance, and gravity.
2. How does the velocity of rain change in a moving reference frame?
In a moving reference frame, the velocity of rain will appear to change due to the relative motion between the observer and the rain. For example, if an observer is moving towards the rain, the velocity of the rain will appear to increase.
3. Does the velocity of rain change in different weather conditions?
Yes, the velocity of rain can be affected by different weather conditions. For instance, strong winds can cause the rain to fall at an angle, changing its velocity. Additionally, air resistance and gravity can also play a role in the rain's velocity in various weather conditions.
4. How is the velocity of rain calculated in different reference frames?
The velocity of rain can be calculated by dividing the distance traveled by the rain by the time it takes to travel that distance. However, in different reference frames, the distance and time may appear differently, so the calculation of the rain's velocity may vary.
5. Can the velocity of rain be the same in all reference frames?
No, the velocity of rain cannot be the same in all reference frames because it is affected by the relative motion between the observer and the rain. Therefore, the velocity of rain will appear differently depending on the reference frame of the observer.
9K
